![]() | Home > Maintenance & Mods (L322) > Rear bulb change |
| jordon0 Member Since: 06 Mar 2016 Location: derbys Posts: 54
sorry but the lens/cover are all one unit ie can't be split to take light units out |
| TonyB Member Since: 02 Oct 2017 Location: Hampshire Posts: 14
Many thanks. So, any bulb goes then the entire cluster is unservicable? |
yes if any of the leds go out a whole new unit is needed
| V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 381
Check that it is not a wiring issue using a multimeter before you go to the expense of a new light unit. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790
The rear lights on a 2012 are fully LED, no bulbs to change. If you have a light out then you either have a wiring issue as said or a duff light unit.
Thanks for the tip! |
| All times are GMT |
