Home > Technical (L322) > No brake pedal
Jack last
United Kingdom 2005 Range Rover Vogue Td6 Zermatt Silver
No brake pedal
Hi all recently changed 2 front brake pipes and front pads
also 2 rear flexi pipes then onto bleeding the brakes
But can’t get decent pedal
Straight to floor there is a pedal when engine is off but when running nothing
Tried bleeding manually and with a brake kit
When pumping brake pedal there is an air sound from the servo area is this normal?
Any ideas?
Cheers
Post #572108 7th Nov 2020 6:47pm
I don't know why you are having trouble bleeding the brakes but the air sound from the servo is normal. When you press the brake pedal and therefore move the servo diaphragm forward air is drawn in behind the diaphragm through a filter surrounding the push rod from the brake pedal. Thumbs Up
Post #572114 7th Nov 2020 7:59pm
Jack last
Yes thought that was normal I’ll try bleeding again tomorrow been at it a week though Big Cry
cheers
Post #572116 7th Nov 2020 8:02pm
