Home > Technical (L322) > First breakdown ! |
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 154 |
Well it's finally happened, the Range Rover that has been faultless for just over two years has finally broke down and ended up on a flatbed. In fact it ended up on 2 within the space of ten minutes !
11th Nov 2020 9:13pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7631 |
I’m not sure, but I think the engine will shut down if it thinks there is no fuel. Even if there is some in. A long shot I know...... Or you may be lucky... As you say, just ran out of fuel.
11th Nov 2020 9:39pm |
Thanks RJFF, I'm expecting the garage to contact me today with an update, the garage owner is an enthusiast who has owned a few and built a few too.
12th Nov 2020 8:56am |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1193 |
TJ
12th Nov 2020 2:07pm |
Hi all, my suspicions were confirmed today I had indeed ran out of fuel ! It looked like the tank had at least a range of 60 miles when it broke down and the fuel low warning light did not work on this occasion. Only spoke to the receptionist who said the car was now running normally and that the owner of the garage confirmed it had ran out of fuel. Said the bill was £90 which included £20 worth of diesel so not sure what they've done. The car was booked in at the same garage for next week so they will do that work tomorrow instead and I should have a clearer picture when I pick it up tomorrow, the car passed its MOT a Few weeks ago but had drive shafts and bushes on the advisories so that will be done tomorrow.
12th Nov 2020 9:14pm |
Yayyyy
12th Nov 2020 9:26pm |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 |
I bet the difference was diagnostics, and bleeding/priming an empty fuel system... |
13th Nov 2020 8:45am |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
this was my fear while my tank was not reading correctly so was just using half a tank of fuel all the time whe the fuel light came on had to fill up! all fixed now thank god. Glad to hear that is the only problem 2012 Vogue 4.4 TDV8 - Current
13th Nov 2020 9:03am |
I agree, diagnostics there usually about £44 so seems about right it came to £90 which I can live with. Will probably attempt the sender repair myself when work permits as certainly looks doable. |
13th Nov 2020 4:19pm |
