Home > Maintenance & Mods (L322) > Steering wheel..aghhh
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Cant get the steering wheel off of a 2004 petrol. Need to replace something called the clock spring. Poked things down the two small holes on each side of the wheel but they dont release the airbag and switch assembly like they do in a video I've just watched.In te vid, it just pops off no trouble !!
Post #572601 12th Nov 2020 7:36pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
These can be very fiddly. You need a small long screwdriver to fit in the hole. You can release one & then have it locate again, when you attempt to release the other side.
I have an old flat head screwdriver, which I have filed a V in the end of it.
What you are trying to do is release the spring holding the pin down, whilst apply a little pressure to the air bag. It doesn't need a lot of pressure, just aligning correctly.
***** Make sure that the vehicle has been shut down for at least 10 mins before attempting this***
Keep at it Thumbs Up
Post #572603 12th Nov 2020 7:50pm
mjdronfield
I put a new steering wheel on my TD6. Getting the airbag off was the worst bit Rolling Eyes
I did a thread here..... pic of the spring is on the second page if it helps...
https://www.fullfatrr.com/forum/topic13068...p;start=15 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #572617 12th Nov 2020 9:13pm
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
On my D3 I got an air bag removal tool. You have to locate the tabs inside and pull them outwards to release the airbag. There is a video by Powerful here that shows how to do it.
HTH
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #572649 13th Nov 2020 10:36am
Highroller
Ivan, Different tool & process for the L322 unfortunately.
The hole in the Air bag unit is only about 4 mm & the release spring is sat about 50 mm further in.
Powerful video is good though. Thumbs Up
Post #572650 13th Nov 2020 10:46am
IGP
OK no worries 2013 Vogue SE SDV8
Post #572651 13th Nov 2020 10:47am
Weegie
@DaveK, You just have to keep fiddling with it until you hit the right spot.
Depending on what you have if you have a heated steering wheel and are buying a used clock spring, make sure that it specifies heated wheel on any listing. John
GAP iiD BT
Post #572671 13th Nov 2020 1:58pm
Mr Tee
absolute ballache of a job, took me fooking ages and a gallon of patience.
Post #572677 13th Nov 2020 2:36pm
Gsxr1250dave
This should help, have a look at my flappy paddle thread I made a special tool from a screw driver and took loads of photos to help.
Post #572719 13th Nov 2020 8:08pm
DaveK
Finally removed with a lot of assorted things poked in the tiny holes ! That done, clock spring was a breeze.
Post #572747 14th Nov 2020 1:28am
Highroller
Thumbs Up Gsxr1250dave's photo's should have helped. Looking at the second photo, you can see that it's missed a few times & how tricky it is. Whistle
Post #572757 14th Nov 2020 10:18am
