![]() | Home > Maintenance & Mods (L322) > Steering wheel..aghhh |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 569 ![]() ![]() ![]() |
These can be very fiddly. You need a small long screwdriver to fit in the hole. You can release one & then have it locate again, when you attempt to release the other side.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7965 ![]() ![]() ![]() |
I put a new steering wheel on my TD6. Getting the airbag off was the worst bit |
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 300 ![]() ![]() ![]() |
On my D3 I got an air bag removal tool. You have to locate the tabs inside and pull them outwards to release the airbag. There is a video by Powerful here that shows how to do it.
Ivan, Different tool & process for the L322 unfortunately.
OK no worries 2013 Vogue SE SDV8
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
@DaveK, You just have to keep fiddling with it until you hit the right spot.
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2709 ![]() ![]() ![]() |
absolute ballache of a job, took me fooking ages and a gallon of patience. |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1026 ![]() ![]() |
This should help, have a look at my flappy paddle thread I made a special tool from a screw driver and took loads of photos to help.
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 792 ![]() ![]() ![]() |
Finally removed with a lot of assorted things poked in the tiny holes ! That done, clock spring was a breeze. |
