![]() | Home > Technical (L322) > What is this pipe? |
Jack last Member Since: 29 Aug 2020 Location: Scotland Posts: 50 ![]() ![]() ![]() |
Anybody know pipe in middle of pic just noticed it’s
jim4244 Member Since: 31 May 2012 Location: UK Posts: 855 ![]() ![]() ![]() |
Have you a photo showing a little bit more of the engine. I can’t work out where you are looking?
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7995 ![]() ![]() ![]() |
I’m guessing it’s a breather, but need a pic from further back.... as can’t tell exactly where that is....
There is a gearbox breather, but I think that might have a filter on, that goes nowhere. 2011 Range Rover Vogue SE 4.4 TDV8
So not needed then? |
Well it’s needed, just not connected to anything. Best not to look for issues. They will find you soon enough 🤣 2011 Range Rover Vogue SE 4.4 TDV8
Well it’s running fine just no brakes that’s another story!
stuart_2006 Member Since: 18 Jul 2018 Location: Holsworthy, Devon Posts: 133 ![]() ![]() ![]() |
Wisdom elsewhere on the forum suggests that pipe is the breather for either the transfer box or the front diff (and it should be clipped onto that clip right next to it). There's another plastic pipe nearer the back of the engine that comes up and is bent in a semi-circle so the open end points down - that's the other breather. There's also a small clear plastic filter in that area that is open at one end - that's the gearbox filter. |
Hi there Stuart so how many connections do I have to make here exactly?
Well you don't have to make any connections ... all the pipes are designed to be open at the end in the engine bay.
Ah ok so all is well then
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3272 ![]() ![]() ![]() |
They are open end so they can breath. They are up where they are so that the gearbox/transfer boxes don't flood when wading. John
