![]() | Home > Technical (L322) > No squirt rear wiper? |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
Nice one just replaced the rear wiper!! and notes water not flowing properly. will be a job to do this weekend |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2249 ![]() ![]() ![]() |
Right back on this. Where does the rear window water tube run? On the new headlining I have replaced the old with it ran across the headlining (from a 2012 car) but when I took down my headlining a couldn’t see it? The new one looks like it ran down the passenger pillar again couldn’t see it? Current stable:
Jimnic007 Member Since: 13 Aug 2019 Location: Cheshire Posts: 77 ![]() ![]() ![]() |
Which way should the arrow be pointing on the NRV? Does it point towards the motor, or away from it?
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Arrow points in the direction of flow, points to the wiper motor/arm/jet |
Thanks. I think this may be blocked, as every time I squirt it, the hose pops off from the force of the water . |
Mine can be taken apart with two small jewelers screwdrivers. Had to back flush the washer jets as they had calcium build up and kept blocking after cleaning the jets with a needle |
Thanks.
Ok my non return was damaged trimmed the gasket now it pours water out of the inlet from the motor...
Ashmyster79 Member Since: 07 Nov 2020 Location: Essex Posts: 247 ![]() ![]() ![]() |
I did mine last week. The motor was caked in mud. I took the whole motor apart you can see where it is clogged from there backwards. As above mine leaks water from where the non-return value sits on the motor body an ever so slight gap. I silicone it a little but have yet to test the water. when I did pre silicone it went in the plastic tray. I used some compressed air, pipe cleaners and a metal skewer from the bbq to clear it all. If it's blocked further back I wonder if there is a kit to pressure flush through the tube from front to back. I am not clever so apologies if this is not possible. |
