Home > Technical (L322) > 4.4 tdv8 turbo replacment
eddyeggs
hi,
just a quick question , does anyone know if the turbos on a 4.4 tdv8 ffrr can be changed without lifting the body off like the rrs models.
Post #572824 14th Nov 2020 10:02pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
You’d hope so given an L322 is monocoque!
Post #572832 14th Nov 2020 11:14pm
DrRob
Yes. I had my secondary one changed at Rovertune due to it leaking and no body off Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #572833 14th Nov 2020 11:25pm
mjdronfield
The body can’t come off. It doesn’t have a separate chassis. If a garage says body off, use a different garage 🤣
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #572841 14th Nov 2020 11:58pm
chugga90
It is similar to body off. It’s a subframes that the engine is mounted on and can be dropped out for work access. However dropped out is quite a simple term for the task!
Post #572850 15th Nov 2020 8:46am
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
I’ve also had the secondary turbo replaced. No need to drop subframe, engine stays in situ 2011 TDV8 Vogue SE
Post #572858 15th Nov 2020 10:25am
