Home > Technical (L322) > Improve FBH 2011
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
JNC wrote:
How long should it run for at a time? I tried it this morning as the temp was less than 6 degrees.
The fob flashes green for some time, when it stopped I pressed it again. Repeated several times, I guess the run time would have been 30 minutes or so.
Got in the vehicle and heater was still cold.
I have had to change coolant within last 6 months, I wonder if that side of the system has an airlock?
Does the heater ramp up after it's started, does become quite a roar if running correctly. If you look underneath (nearside front) you should see it's exhaust which should be hot enough for your skin to stick to it if it's running at full power. If you're not getting warm air inside, check that the electric water pump is running, if it isn't the water in the heater gets hot, doesn't go anywhere and the heater shuts down because the water is hot. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #572199 8th Nov 2020 7:49pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
When MY11 was first released, run time was 30 minutes
But LR had put new software on the battery management CPU
Where battery no longer fully charged. Very very very slight saving on fuel....
folks were finding that after a 30 minute run of the FBH, the car was warm but battery was flat
main dealers changed FBH run time to 17 minutes with new download from LR
Some claim their cars are warm and toasty after 17 minutes
Mine certainly is not
Side mirrors no longer de-ice when FBH is running
You can return to 30 minutes at your peril
17 minutes are enough to clear windscreen
Post #572238 9th Nov 2020 8:30am
mjdronfield
Sounds about right.
Piggin thing struggles to power the clock when the engines not running 🤣
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #572252 9th Nov 2020 10:29am
Rapiscan
England 2007 Range Rover Vogue TDV8 Santorini Black
With the timer set on mine it works completely randomly, with full tank or only say a third, makes no diff , one morning it's on, another it just doesn't switch on?? Baffling! Rolling Eyes 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
I used to be indecisive and have a split personality... but we are ok now...I think?
Post #573096 17th Nov 2020 12:01am
kooky_guy
I'm suspicious that my changeover valve isn't isolating the matrix which is why mine doesn't get very warm. It defrosts the windscreen, but really doesn't warm the interior much.
Not got round to investigating it though. Anyone know of an easy check? 2010 4.4 TDV8 Vogue SE
Post #573141 17th Nov 2020 10:26am
mjdronfield
That’s all mine does to be fair. It doesn’t run for that long, so it’s not going to be As warm as like When the engine is running. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #573162 17th Nov 2020 10:43am
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
I had the opposite a few months ago. The o ring in the valve was swollen so didn't allow engine coolant into the system.
Post #573166 17th Nov 2020 10:51am
