![]() | Home > Technical (L322) > New Rave CD or help required on Handling management fault. |
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 ![]() ![]() ![]() |
Can anyone guide me to either renewing my Rave CD (I cannot run anymore), or telling me where the abs valve relay is. It keeps coming up as a fault when the system involving abs traction control suspension inactive etc. This occurs when I accelerate at a junction or corner fast enough to trigger all the handling controls . It all clears after an ignition switch on/off. So it triggers in , surely it would cancel and revert back to normal, but it doesn't and sends a fault |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7991 ![]() ![]() ![]() |
There are reports of RAVE no longer working on versions of Windows 10, if that’s what you are using.
Not sure what you mean by the ABS valve relay ?
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1583 ![]() ![]() |
Correct, RAVE no longer runs on WIN 10 later than 1903. One needs the hacked version that will run with standard versions of Acrobat. Ron B. VK2OTC
That’s great I’ll try that. it just goes no further than Acrobat.
That’s excellent now running. And searching my problem , but no abs relay . Thanks for that clever conversion. |
Going back to my original problem, and looking for relays , there is on listed in the abs electrical circuit , but can’t find it on the car . I have also picked out a 5 amp fuse that was in the wrong place so that wouldn’t help . Not sure if the anti lock brakes are working come to think of it, so will test that tomorrow. |
Odd, I tried it again today with Win 10 1909 and it works. ![]() V015-2
I tried this with several of my RAVE discs and none brought up the compatibility tab when I right clicked on RAVE.EXE. Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 612 ![]() ![]() ![]() |
I don't run direct from the cd, I copied to my PC and created a shortcut on my desktop. I then applied the compatibility on that shortcut.
