Home > Maintenance & Mods (L322) > 4.4 tdv8 high pressure pump noise
GraemeS
I get to feel an engine vibration / harshness possibly at around 2500 rpm which occurs when the transfer case mount bracket is filled with hardened mud. I dig out the hard dirt with a big screw-driver.
Post #573486 19th Nov 2020 9:15pm
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
I have run it with the longer drive belt off and made little to no difference.
I have ordered a fan pulley. So will run it with that belt off too. Will check crank pulley at same time.
Post #573506 19th Nov 2020 10:26pm
Sonearly
The tapping only appears after engine has warmed up also, can be heard loudly through the front grill. Use a mechanic scope the sound definitely originates from the HPFP, sounds like a bag of nails through that. The noise is not engine speed reliant.
No significant vibration, slight felt when slowing done and engine drops below 1000 revs briefly
Post #573514 19th Nov 2020 10:56pm
JNC
By design they are obviously quite noisy hence the soundproofing. The tdv8 is a particularly quiet engine compared to most Diesels.
The part number changed a few times, not sure if part was slightly redesigned.
Post #573515 19th Nov 2020 11:00pm
Frans@Yamorna
South Africa 2012 Range Rover Vogue SE TDV8 Zambezi Silver
The rubber damper on the crancshaft pully failed on my car.With car idle use a strong torch to check the pully for wobble.There was no vibration of engine. 2012 TDV8 Vogue SE 4.4
Post #573689 21st Nov 2020 8:44pm
Sonearly
Ticking noise gone.
I have run two tanks of fuel with injector cleaner additive and the noise has reduced to barely noticeable.
Post #577248 26th Dec 2020 3:31pm
kevinp
What magic brew did you use?
Post #577274 26th Dec 2020 7:27pm
Sonearly
Carlube Diesel Fuel Injector Cleaner
I bought it from Sainsbury’s , £4.99.
Was recommended by MB master mechanic, he said they use it all the time on Mercs that fail MOT’s. He advises every 4th tank full on an ongoing process.
Post #577280 26th Dec 2020 8:30pm
alfredlervaag
Norway 2012 Range Rover Autobiography 4.4 V8 Santorini Black
noise from high pressure pump
https://video.fosl4-1.fna.fbcdn.net/v/t42....F&dl=1
the mecanic says see for a new pump....
Post #600184 9th Jul 2021 10:02pm
