![]() | Home > Technical (L322) > 2010MY Keys - deleting all previous |
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 351 ![]() ![]() ![]() |
Specifically for a 2010 or later model year, the GAP IIDtool can add a new key and show how many keys are coded and in range of the car, but doesn't seem to be able to delete an old key (there are instructions for this in the manual but it's specific to <2010 cars).
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
The procedure using my xtool was that it removes all keys first, and then adds the new keys. Always scares me in class I’m left with no working keys. 🤣 But as that tool can read the security codes of as good as any vehicle it’s ok. I wonder whether GAP IID does the same. |
Is your car a 2010MY?
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1100 ![]() ![]() ![]() |
Well, you're correct on all counts
Shame you are in Barcelona. Otherwise I could use my xtool to remove them for you |
Doh! This is a rather odd thing for it not to be able to do :\ What is SDD? Thanks! |
Double doh! I'm amazed the IIDTool can't do it as it seems to have pretty full access for everything else ![]() Oh well, at least I should be able to get garage to do it for me if I can find one with a tool that does it ![]() |
Garages would commonly get a (automotive) locksmith for that, unless using a dealer with dealer tools and prices. As such you may want to reach out to a locksmith. |
Patrick @ GAP confirmed this isn't possible with the IIDTool right now, only adding can be done.
SDD = Symptom driven diagnostics -- it's the proper JLR tool Current: 2011 FFRR Vogue SE 4.4 TDV8
Ah, looks a trip to a stealer perhaps then, I can see some other "VXDIAG" tools which seem to say they can reprogram keys but again, could be like the IIDTool and it only adds rather than deleting.
