Home > Maintenance & Mods (L322) > TD6 turbo
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
TD6 turbo
Hi all
Silly question but how do I know that my turbo is working?
Before I had my vacuum pipe problem I used to be able to hear my turbo whisking away happily. Now I don’t hear the whistle , fuel consumption has gone from 25mpg down to 18mpg and a sucking noise from the off side og the engine bay.
Any TD6 gurus out there?
Jim
Post #573723 22nd Nov 2020 10:27am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Have you seen the turbo actuator actually moving? I think I am correct that it goes through a test cycle at startup. You can view it move from above. Have you inspected the boost hose from the turbo to the intercooler? I suppose it is possible that whilst the vacuum hose was off the variable vanes would obviously not be moving and have stuck in the open position. on the back of the inlet manifold is a boost pressure sensor. ensure it is plugged in, also a good idea to remove the sensor and give it a good clean  2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #573797 23rd Nov 2020 11:13am
