![]() | Home > Maintenance & Mods (L322) > TD6 turbo |
| wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 808
Have you seen the turbo actuator actually moving? I think I am correct that it goes through a test cycle at startup. You can view it move from above. Have you inspected the boost hose from the turbo to the intercooler? I suppose it is possible that whilst the vacuum hose was off the variable vanes would obviously not be moving and have stuck in the open position. on the back of the inlet manifold is a boost pressure sensor. ensure it is plugged in, also a good idea to remove the sensor and give it a good clean 2007 TDV8 VSE
| All times are GMT |
