![]() | Home > Technical (L322) > 4.4 TDV8 - Blown Turbo @ 50k miles |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7965 ![]() ![]() ![]() |
The 4 rubber hoses on the inlet donut are are known issue, and can cause restricted performance.
CMC15 Member Since: 15 Mar 2019 Location: Wirral Posts: 22 ![]() ![]() ![]() |
Hi mj, they were replaced around 2 months ago but thanks for the heads up!
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2590 ![]() ![]() ![]() |
Chris, I am no spanner but surely if a turbo has gone. its bloody gone, sounds like it is doing something once it reaches a certain temperature, hope it is minor |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2731 ![]() ![]() |
Make sure that the secondary inlet isolation valve isn't sticking. It was redesigned to overcome this fault.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
If it drives normally when reset then it’s not likely to be the turbo. More likely a boost leak.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
+1 boost leak
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
Get a second opinion from a specialist Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
This is good advice, I would definitely get a second opinion before parting with £3k ![]() |
Could be a sticking turbo valve. This is located at the front of the engine and has been a known problem and there is an updated part for it.
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1099 ![]() ![]() ![]() |
I agree with all the input here -- I think we're collectively saying if it's a blown turbo 'they'll eat my hat' something is leaking or something is sticking |
It's quite easy "when you know how" to see if the CSOV mod has been done or not by looking down the front of the engine from just off centre towards passenger (UK) side. Use a torch. If it has the original "nut" fitting then first try and ease it loose as per the thread below with WD40 etc.
Guys, thanks very much for the comments. Currently awaiting the results of a smoke test. All 4 donuts were replaced with silicone about 2 months ago.
Maybe a stupid question but if it is value/actuator then they can be replaced as isolated parts not requiring full replacement of the turbo, otherwise it's either going to be a full replacement of the entire system or the faults will just keep occuring as things stick?
The inlet manifolds have revised part numbers and an occasional original one has developed a split. |
