Home > Technical (L322) > 4.4 TDV8 - Blown Turbo @ 50k miles
CMC15
Hi All, my 2011 4.4 TDV8 went into to restricted performance yesterday and had to be recovered to a reputable specialist. I have been told it is likely that is has blown the large turbo and is a circa £3k bill to replace!
Once the car is turned off and then turned back on after a minute or so, the fault message is gone and the car will drive fine for a while with full power available and no apparent issues, until it comes back.
I would have thought that if the larger turbo had an issue then boost pressure/performance would be lost.
Car only has 50k miles and services every 6 months with top quality oils and has never suffered to knowledge oil starvation to the turbos.
I regularly rev the engine out and load it to ensure the second turbo is up to temp to avoid the known issues with limited used TDV8s.
Any ideas as to if it is likely to actually be the turbo?
Many thanks all.
Chris
Post #574092 25th Nov 2020 6:27pm
mjdronfield
The 4 rubber hoses on the inlet donut are are known issue, and can cause restricted performance.
Worth a check for splits.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #574093 25th Nov 2020 6:36pm
CMC15
Hi mj, they were replaced around 2 months ago but thanks for the heads up!
Cheers, Chris
Post #574094 25th Nov 2020 6:40pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Chris, I am no spanner but surely if a turbo has gone. its bloody gone, sounds like it is doing something once it reaches a certain temperature, hope it is minor Thumbs Up
Post #574098 25th Nov 2020 6:52pm
GraemeS
Australia
Make sure that the secondary inlet isolation valve isn't sticking. It was redesigned to overcome this fault.
Note that the larger turbo is the primary, not the secondary, and the primary's own linkages can become sticky.
Post #574104 25th Nov 2020 7:29pm
If it drives normally when reset then it’s not likely to be the turbo. More likely a boost leak.
Get them to do a smoke test on it to see if it has a leak somewhere. There is nothing that can't be fixed with a hammer😜😜
Post #574107 25th Nov 2020 7:53pm
GGDR
+1 boost leak
. Cheers, Greg
Post #574111 25th Nov 2020 8:00pm
DrRob
Get a second opinion from a specialist Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #574112 25th Nov 2020 8:01pm
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
This is good advice, I would definitely get a second opinion before parting with £3k Rolling Eyes 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #574165 26th Nov 2020 10:26am
Could be a sticking turbo valve. This is located at the front of the engine and has been a known problem and there is an updated part for it.
Have a look here
https://www.fullfatrr.com/forum/topic37268.html There is nothing that can't be fixed with a hammer😜😜
Post #574179 26th Nov 2020 11:38am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
I agree with all the input here -- I think we're collectively saying if it's a blown turbo 'they'll eat my hat' something is leaking or something is sticking Smile Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #574195 26th Nov 2020 12:47pm
DrRob
It's quite easy "when you know how" to see if the CSOV mod has been done or not by looking down the front of the engine from just off centre towards passenger (UK) side. Use a torch. If it has the original "nut" fitting then first try and ease it loose as per the thread below with WD40 etc.
https://www.fullfatrr.com/forum/topic55919.html?highlight=csov
Typing "CSOV" into the Search function might bring up more. https://www.fullfatrr.com/forum/search.php
Did you replace the 4 donut inlet ones for silicone versions?
PS Name and shame your so called specialist who's looking to pull a fast one here I reckon. He's simply throwing parts at it and not diagnosing it. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #574198 26th Nov 2020 1:22pm
CMC15
Guys, thanks very much for the comments. Currently awaiting the results of a smoke test. All 4 donuts were replaced with silicone about 2 months ago.
It does sound like something is sticking. For me, if the turbo has/has gone, then there simply wouldn’t be the performance available as soon as you restart the car.
There is also a missing of oil on the rear left hand donut if that sheds any further light on known issues?
Will keep you updated and massive thanks again.
Chris
Post #574223 26th Nov 2020 7:13pm
CMC15
Maybe a stupid question but if it is value/actuator then they can be replaced as isolated parts not requiring full replacement of the turbo, otherwise it's either going to be a full replacement of the entire system or the faults will just keep occuring as things stick?
Thanks.
Post #574224 26th Nov 2020 7:19pm
GraemeS
Australia
The inlet manifolds have revised part numbers and an occasional original one has developed a split.
Post #574227 26th Nov 2020 7:39pm
