Home > Technical (L322) > L322 TDV8 Oil Change |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
Hi all,
8th Nov 2020 5:40pm |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 667 |
Yes,
8th Nov 2020 5:47pm |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 468 |
That Sealey pump is identical (other than the stickers) to the one I use which I bought from Lidl
8th Nov 2020 5:54pm |
Just an update on my experience with the electric pump used to remove the oil.
29th Nov 2020 10:55am |
Wow, that's slower than I'd expect.
29th Nov 2020 5:23pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4234 |
The Draper Expert 10L is the vacuum of choice Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
29th Nov 2020 6:41pm |
yes oil was fully hot when extracted.
29th Nov 2020 6:49pm |
just an update since the service on my Fatty. The engine seems so much quieter (I already though it was quiet) and pick up seems more responsive too. not noticed MPG increase but over all much quieter, i can only think the last lot of oil was sub par or the wrong grade even cold start in the morning it does not seem to give that diesel clatter.
1st Dec 2020 11:36am |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
Blank your egr’s and the oil will stay cleaner and last better! I haven’t blanked egr’s before but am amazed by how clean the oil stays, it’s almost petrol like for how the oil stays clear. Coming from an ex-master tech who has serviced many 1000’s of cars over the years. |
1st Dec 2020 12:44pm |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 662 |
ur20v: I don't believe you can blank the EGR's on a 4.4 TDV8, something to do with the ECU........but stand to be corrected. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
1st Dec 2020 1:26pm |
yes i hate the fact i cannot keep engine oil clean in a diesel. I used to have the original Focus RS that was a 400HP monster i did 80k in it fully tuned i used to do an oil change every 3k and it came out like it went in!!
1st Dec 2020 2:27pm |
4.4 needs the EGR to work for DPF etc.
1st Dec 2020 2:31pm |
RRover Member Since: 17 May 2021 Location: Sussex Posts: 278 |
Reading this thread had me thinking about the ideal or accepted oil level setting as far as the electronic instruments screen readout goes...
17th Apr 2023 10:53am |
I have mine at one or two notches above mid point when COLD.
17th Apr 2023 1:50pm |
