![]() | Home > Maintenance & Mods (L322) > MOT failure - brake pipes. Was this a reasonable price? |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3269 ![]() ![]() ![]() |
This thread started in 2015 covers it. I had mine done on the Td6 a few years ago.
Hermes Member Since: 07 Nov 2020 Location: Oop north Posts: 108 ![]() ![]() ![]() |
If it makes you feel better, I need a new rear (wheel to wheel) brake pipe on the 996....
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Couple of comments, make sure they are not using copper brake pipe, they should either OEM steel lines or use kunifer pipe, it’s burst pressure and durability is much better than copper. At the price they have quoted it should be Kunifer.
I seem to be at cross purposes. I thought the post was about a recall and not about the original thread.
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2717 ![]() ![]() ![]() |
My local MOt place always states the undertrays nonsense too.. " we have to put that on now " . Sorry Stan , yes off topic.. |
The governments wed site on MOT’s even advises against issuing an advisor ‘under trays fitted’ if OEM. The gov. Are looking to issues further advice to testers on this.
The governments own wording:
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 403 ![]() ![]() ![]() |
I've done brake pipes on a L322 about 10 times now. For what it's worth, these are my thoughts:
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 613 ![]() ![]() ![]() |
Just had mine done front and back £250 in copper |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 546 ![]() ![]() |
Seems about right, 4 hours work @£60 and a tenner for the roll of Cunifer. 1992 RR Classic 3.9 efi Vogue
Did you have the flexi pipes changed and the pipes from the flexi to the calliper as well for £250, or just the main front to back pipes? The genuine flexis are about £40 each, though you can get them much cheaper as a pattern part. Current: - 2017 L405 3.0 V6 Autobiography Sold: - 2013 L405 4.4 TDV8 Vogue - 2004 L322 4.4 Vogue (BRC LPG) - 2002 L322 4.4 HSE (having fixed timing chain guides) - 2000 P38 4.6 Vogue (BRC LPG) - 1981 2-door In-Vogue - 1980 Ex-Army SIII LWB - 1976 SIII LWB - 1968 SIIA Stripped for parts: - 2003 L322 4.4 Vogue |
Flexi pipes not changed just front pipes and rear pipes oh yeh and an mot included |
