Home > Technical (L405) > Deployable (deplorable?) towbar.
Jon Knapp
United Kingdom 2013 Range Rover Vogue TDV6 Santorini Black
Hi everyone,
First posting from me, please be gentle.
I own an L405 V6 2013. I have a deployable towbar stuck in deployed position with buzzer going off all the time with both leds flashing. Red on power switch and green on operation switch. Any help would be much appreciated.
Thanks, Jon.
Post #574788 1st Dec 2020 7:07pm
hello Jon and welcome to the forum...
this is a pdf from the WM [ link in our wiki] .....it explains how to test the towbar and hopefully reach a solution..
https://www.fullfatrr.com/gallery/albums/u...ESTING.pdf ... - .- -.
Post #574791 1st Dec 2020 7:15pm
Jon Knapp
Wow that was quick. Thanks Stan.
Post #574793 1st Dec 2020 7:17pm
Jon Knapp
So. I have followed the link to reset/fault find the towbar. I cannot get past A5 which points you towards the module. I assume this is in the boot on right. Haven’t found it yet but assume because my car is 2013 that it has an early module and that it needs replacement. I can get hold of the latest spec AG part is this a good idea or should I just buy an identical part with AF part code? It says use campaign code Q602 initialise. So what is the code and how do I initialise ?
Thanks. Jon.
Post #574842 2nd Dec 2020 12:46pm
sounds like its getting to the stage where a dealer or garage should get involved...
you could start replacing bits but a proper diagnostic check might pinpoint something else.. ... - .- -.
Post #574843 2nd Dec 2020 12:59pm
Jon Knapp
Thanks Stan. I’ll find the module and if old I’ll bring up to date with newer part. First I’ll try down powering it and switching it back on. This my fourth Range Rover, they can be testing!
Post #574844 2nd Dec 2020 1:03pm
just an afterthought Jon, are all the towbar joints clear of crud and dirt, maybe a liberal spray of WD40 might help.. ... - .- -.
Post #574845 2nd Dec 2020 1:11pm
Jon Knapp
I’ve found the module. It requires the removal of the inside panel on the right of the boot to be removed in one piece. Just to find that it’s between the spare and under the lash down strip which also needs removal. Then two ten mm nuts see photos. I am ordering the latest AG module as mine was AE! Will let you know what happens next.
Post #574862 2nd Dec 2020 3:04pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
The campaign code is for the dealer to recharge the issue under warranty. The early AE modules are the ones which had issues, an AF or an AG should be fine. I don't remember it being too much of an issue to get to the module - removing the three bolts that holds down the tailgate flap means you can move the carpet easily to get to it without having to remove the spare wheel.
If the module doesn't fix it there has been problems with the wormgear within the towbar mechanism shearing a tooth and wedging the gears. There is a powerful video on how to fix if you are handy, otherwise you may need to get a replacement -plenty on ebay. Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #574865 2nd Dec 2020 3:48pm
Jon Knapp
Very useful, thanks Nick. AG on its way. If not that then suspect you are right and it’s the worm gear. I’m handy so would try to fix it. I saw powerful! Many thanks, Jon.
Post #574866 2nd Dec 2020 3:54pm
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
This is the video of how to fix one.
HTH
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #574867 2nd Dec 2020 3:55pm
Jon Knapp
Thanks Ivan. This was the YouTube I hadn’t watched! Fairly sure my problem is the same as theirs. I had previously retracted the towbar with a seven pin adapter on it. It had struggled and wound back to deploy position. Will hunt for this part. Does anyone know where I can get one? Or what part no. It is?
Post #574870 2nd Dec 2020 4:18pm
IGP
Might be worthwhile giving Powerful a shout and see where they got their part from.
Post #574872 2nd Dec 2020 4:36pm
nicksaab
I'm not sure if they ever did find the part - I thought they just removed the broken bit of gear and it worked. However its unlikely that leaving the 7pin socket in would have broken the wormgear (done it loads of times myself) it detects it and backs it out so sounds like it did what it was supposed to but hopefully its just the module which is fried. Fingers crossed for you anyway - I don't fancy rebuilding that wormgear. Current Fleet:-
Post #574881 2nd Dec 2020 7:48pm
Jon Knapp
Thanks, fingers crossed as I can’t find the part anywhere including Westfalia.
Post #574891 2nd Dec 2020 9:22pm
