![]() | Home > In Car Electronics (L322) > Streaming Music From My iPhone 6s to my L322 |
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 351 ![]() ![]() ![]() |
Is your "Apple connector" a genuine Apple cable? Not all cables are equal, unfortunately, the genuine Apple cable should provide analog and usb audio out, which should, theoretically work with the land rover iPod cable. ** EDIT ** As per the video posted above, there's a suggestion a voltage converter is needed too... Last edited by Siftah on 6th Dec 2020 12:34pm. Edited 1 time in total |
Kind of surprised with the need for the voltage converter, that's a new one on me but his video shows it working so, that kind of trumps everything ![]() I can't see that the Bovee does anything that doesn't do, it just does it wirelessly. Potentially less audio quality over the bluetooth link too, theoretically the cabled link will have the potential to sound better. The Bovee still needs the Land Rover to 30-pin cable. As per the video, no reason why you can't stream music from Apple Music or Spotify with either solutions. |
Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 410 ![]() ![]() |
I just received these items, and it doesn't work. It sees the phone and that comes up on the screen, the phone charges, but it says "device error". I did some Googling and it turns out that there is a software clash between these cars and the modern Apple software and/or the iPhone 8. However, it seems the USB socket I use for charging that is next to the iPod socket can also be used as an input, and using a genuine Apple lead it gives the same device error. So I am back to square one. ![]() 2018 D300 SE Velar in champagne 2006 Bentley Flying Spur in silver |
Did you try it without the charge converter, same thing? |
Yes I did, Siftah. 2017 4.4 SDV8 Autobiography in black
meh, that sucks |
Yes, it looks like the Bovee thing is the way to go. But I am concerned from the Amazon reviews that 8% of them seem to conk out after two months. 2017 4.4 SDV8 Autobiography in black
Hmm, on the Spanish Amazon page where I bought mine (shows all reviews though), there's no mention of that... https://www.amazon.es/Airdual-Interfaz-Ada...07RMHVJ6P/
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
well mine is used came with my car looks battered but works flawlessly i was supprised at the clarity of sound when streaming from Deezer i can not hear any difference from from my high res MP3 on my USB stick 2012 Vogue 4.4 TDV8 - Current
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
Only the iPod socket can handle the protocol. There is no way the normal USB does that.
Edwardcc Member Since: 21 Aug 2025 Location: Northwest Territories Posts: 7 ![]() ![]() ![]() |
If your RR only supports calls over Bluetooth and music through the old iPod cable, you won’t be able to stream Spotify directly from the iPhone without extra hardware like a Bluetooth audio adapter.
