![]() | Home > Technical (L322) > New Owner - Errors and faults |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
Fingers crossed π€ Sounds like Land Rover uses Microsoft Windows as the operating system in a FFRR. |
Ashmyster79 Member Since: 07 Nov 2020 Location: Essex Posts: 247 ![]() ![]() ![]() |
The guy who sold me the car just called 9:45 pm saying it is definitely the Cats. Said Land Rover when he took it there said it was the cats and needs a new exhaust system. I will see how it goes and try and source one secondhand. This I feel will get interesting!!!
Good excuse for some sports cats and a 3.5β valvetronic exhaust system ππ |
Sounds good to me do you have any links so I can investigate |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 ![]() ![]() |
so are you saying that he replaced the injectors or didn't replace them? if he didn't replace, and all he did was swap some wires around and it then worked ok, it seems likely that the problem will return. |
totally agree. The problem would still be there I feel unless it was loose bolts, unseated or incorrectly installed etc but that is just wishful thinking and not likely.
Some pics of the sparks which were 4 days old and the errors on my ODB and the CO2 emissions machine I put in the car. It is now reading zero all the time which is what we want. Also a list of what work was done on the car by the previous owner however there are no side steps and not sure who poppy is haha |
Yes custom exhausts donβt have to be that expensive. Although not all systems are equal as with everything. And when adding valves, especially when operated electronically via a button the price can double quickly.
**UPDATE TIME....**
Forgot to say anyone in essex needing an exhaust built. Check them out.
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 351 ![]() ![]() ![]() |
Glad you got it sorted! Only spotted this thread today, but glad it had a happy ending |
So am I. Just under Β£2k spent on it over the last 6 weeks of ownership. Was getting to the point it wasn't going to be cost effective but it is fixed. Just needs a good run to appreciate it and charge the battery so it starts OK. Headache has gone though. π Current Cars
