![]() | Home > Technical (L322) > Locked out with flat battery |
| JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 301
Sorry, MY09 TDV6, should have said. |
| Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601
are you not able to use the key to unlock the door? 2012 Vogue 4.4 TDV8 - Current
Nope, nothing doing although on the bright side, after searching the forum I now know it’s something I need to fix. |
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3888
Check underneath, you might just get to attach a jump lead to the starter motor cable.
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8791
You should be able to use the key in the door lock to open it, the lock will be covered by a plastic cover piece which needs popping off. Iirc it’s on the passenger door. You should then be able to put the key in and turn it.
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989
As above you just need to put 12V on pin 9 and an earth on pin 13 of your towing socket. Bits of wire pushed into them and connected to a battery would allow you to open the doors. |
Thanks everyone.
| chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 479
It’s an easy mistake to think that the plastic cover on the passenger door handle is the actual lock, as I found out .... |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
https://www.westerntowing.co.uk/caravan-12s-wiring-diagram/
Thanks Joe, had a look at a few 7 pin wiring diagrams but none make as much sense as this.
| vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 626
Pm sent |
Right then, a plan of action for tomorrow
Tried that and it looked like it needed too much effort to get it off, which either means it not supposed to come off, or it’s another feature unique to some models and not others. I quit before I broke it. |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002
| All times are GMT |
