Home > Technical (L322) > Locked out with flat battery
JoolsB
United Kingdom 2012 Range Rover Vogue TDV8 Buckingham Blue
Hi all, after 10 weeks static I am locked out with a flat battery
Before I order a CTEK and 13 pin adapter, is there anyway of getting in through the tailgate so I can pop the bonnet and jump it off the defender?
Would appreciate a PM if anyone can help, otherwise it’ll be the end of the week before charger and adapter are delivered.
Thanks all
Jools
Post #575826 12th Dec 2020 2:08pm
JoolsB
Sorry, MY09 TDV6, should have said.
Post #575827 12th Dec 2020 2:09pm
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
are you not able to use the key to unlock the door? 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #575828 12th Dec 2020 2:16pm
JoolsB
Nope, nothing doing although on the bright side, after searching the forum I now know it’s something I need to fix. Big Cry
Post #575829 12th Dec 2020 2:24pm
Baltic Blue
Check underneath, you might just get to attach a jump lead to the starter motor cable.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #575842 12th Dec 2020 5:06pm
You should be able to use the key in the door lock to open it, the lock will be covered by a plastic cover piece which needs popping off. Iirc it’s on the passenger door. You should then be able to put the key in and turn it.
Failing that the easiest way is to put some power in via the tow bar. There is nothing that can't be fixed with a hammer😜😜
Post #575845 12th Dec 2020 5:16pm
As above you just need to put 12V on pin 9 and an earth on pin 13 of your towing socket. Bits of wire pushed into them and connected to a battery would allow you to open the doors.
Post #575849 12th Dec 2020 5:54pm
JoolsB
Thanks everyone.
So the key doesn’t open the door, a common fault and easy fix I find out today Censored
I got hold of a 13 pin socket in an attempt to fashion my own adapter and after much swearing in the rain I find I have 2 x 7 pin sockets at the tow bar...who knew...I use the other thing for towing.
Anyway, anymore suggestions gratefully received.
Post #575850 12th Dec 2020 5:57pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
It’s an easy mistake to think that the plastic cover on the passenger door handle is the actual lock, as I found out .... Rolling Eyes 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
2009 3.6 V8 (MY2010) - my first ever diesel! - now also gone Sad
2004 4.4 V8 Petrol Vogue - now gone
Post #575851 12th Dec 2020 5:58pm
https://www.westerntowing.co.uk/caravan-12s-wiring-diagram/
https://www.disco3.co.uk/shop/tow-electric...c-p45.html
Should get you going.... Thumbs Up .
Post #575852 12th Dec 2020 6:05pm
JoolsB
Thanks Joe, had a look at a few 7 pin wiring diagrams but none make as much sense as this.
I shall try pushing a charger connection into the blue and white first thing. I did try a bodge earlier but I went for the red and then it rained and then I got bored. If no joy tomorrow I’ll splash out on the adapter.
Post #575854 12th Dec 2020 6:10pm
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
Pm sent Thumbs Up
Post #575860 12th Dec 2020 6:39pm
JoolsB
Right then, a plan of action for tomorrow
Plan A - made up a couple of connection wires with socket plugs and going to try the charger route
Plan B - try and get the jump leads on the starter positive
Plan C - try and trip the tailgate manually
If either A,B or C are successful then get into the car, pop the bonnet and jump it off the Landy, or suck it up and get a new battery (might do that anyway).
If none of this works - order a CTEK and 7 pin adapter and cut about in the Landy for a week - which is fine, but it takes ages to heat up in the morning and then it’s super red hot, design feature apparently!
Post #575867 12th Dec 2020 7:22pm
JoolsB
Tried that and it looked like it needed too much effort to get it off, which either means it not supposed to come off, or it’s another feature unique to some models and not others. I quit before I broke it.
Post #575868 12th Dec 2020 7:25pm
mjdronfield
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #575872 12th Dec 2020 7:50pm
