![]() | Home > My Range Rover > New RR now picked Up |
Gr4h4m Member Since: 08 Oct 2020 Location: Chester Posts: 88 ![]() ![]() ![]() |
nice |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1095 ![]() ![]() ![]() |
Looks nice. I had a 3.6 TDV8 which was a joy. Only issues in 4 years were a fuel tanker sender unit, low pressure diesel pump and egr valve. All sorted under warranty. Enjoy it |
Ricardo Villa Member Since: 01 Nov 2020 Location: Worcester Posts: 186 ![]() ![]() ![]() |
Thanks Graham and Andy, hoping the issues will be few ! I always think a well maintained car gives you some hope 😂 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4349 ![]() ![]() ![]() |
Blank the EGRs as a priority to give the turbos a fighting chance.
Yes Dr Rob that's on my priority list! Going to speak to Bodsy on Monday hopefully, did message him but not heard anything. 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
lostinespace Member Since: 19 Nov 2020 Location: Herts Posts: 59 ![]() ![]() ![]() |
My 2009 is sitting in the garage, feeling nervous about using it. The battery goes flat real fast if you keep opening the doors. I have blanked the EGR's and found someone who will map them out and map the car too for £150.
4434Morrison Member Since: 02 Mar 2020 Location: Folkestone Posts: 185 ![]() ![]() ![]() |
Congratulations,
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
Nice car happy motoring 2012 Vogue 4.4 TDV8 - Current
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
That looks very nice.
Thanks guys, for some reason leaving doors open does run battery down, it does on my Jag too. Yes I'm a fan of light interiors and a bit of wood, some say old fashioned but I say class!🤣 Been cleaning leather and treating couple of scuffs with Furniture Clinic product, managed to mix a good match from kit I had for Jaguar, Ivory with bit of yellow seems very close.
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 351 ![]() ![]() ![]() |
Cracking looking car Ricardo! Enjoy and welcome to the club |
Thanks, been very helpful, lot of knowledgeable people on here! 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
It won’t blow proper hot until the engine is warmed up. If you select a hotter temp on the climate, it won’t blow until it can give it to you, unless you override it of course.
No mine seems that way even when up to temp. Taking it in to garage to check it over under warranty. It just seems cooler than it should and it doesn't seem to blow through vents that strongly even on full fan setting. 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
