![]() | Home > General > Laughable Question About Sport Mode.. |
Classic Matt Member Since: 05 Sep 2020 Location: West Sussex Posts: 72 ![]() ![]() |
I am fully prepared to be laughed at for asking this but...
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16363 ![]() ![]() ![]() |
Placing the 4.4 into sport mode is more like a supersport mode on these models... You'll find the car holds gears way up into the rev range and turns the whole car angry! I believe this is why they put the extra step into engaging sport mode, sir... So it's not done accidentally? |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
does it really make that much difference?
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8751 ![]() ![]() ![]() |
Holds gears longer.
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
+1 with Craig on "angry"
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
I have no facts for it; but on my 5.0SC sports mode also seems to alter throttle response. At least it feels like it as the throttle barely needs touching compared to non sport. The dampers are dynamic anyway |
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 351 ![]() ![]() ![]() |
The problem I find when using the flappy paddles in "D" is that as it wants to change up at such a low RPM, you find that telling it to change down is mostly pointless, as the gearbox changes back up almost immediately.
Okay great thanks all. I will give flicking into S a go tomorrow.
Only Time I ever use S is when towing to get the car to hold a higher gear than it wants to in D. I agree that in S it does hold the manual selection properly, but tbh I don’t find myself driving in a way which requires much in the way of holding a lower gear.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
S holds it in gear longer. I use it on slip roads to get above 2500rpm to regulary clear second turbo pipelines |
"Just clearing the second turbo pipelines officer, honest"
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 489 ![]() ![]() ![]() |
Happy to be corrected but I thought sport mode also stiffened the dampers, mine feels tighter when driven spirited on bendy roads when in sport mode. |
Nope. Does nothing to the dampers. It feels tighter when you drive in a spirited manner, because they are adaptive, they tighten up when you give it some... There is nothing that can't be fixed with a hammer😜😜
The more you give it, the tighter it becomes! OOH ERR MISSUS! |
