![]() | Home > Technical (L322) > gearbox td6 l322 |
madcima Member Since: 25 Oct 2011 Location: Italia Posts: 137 ![]() ![]() ![]() |
upgrade: torque converter worn down to iron |
if you have the following problems, stop the car immediately before damaging the gearbox: 1 at a constant speed of 70 km the rev counter oscillates between 1800 1900 rpm
thanks for the info |
Jim42 Member Since: 15 Dec 2020 Location: Scotland Posts: 3 ![]() ![]() |
Hi guys, I'm new to the site,got an issue with gearbox volts,the battery is at full charge putting out 14.6 at tick over and iam getting the proper volts all over the car apart from the gearbox Wich is at 11.8 the car drives fine up to 3rd gear then when it goes for 4th the fail-safes come on,the box was reconditioned 25.000 miles ago with a new tc but the car has been sat for about a year, I've done a gearbox filter change as well there was a small amount of glitter in the sump but nothing startiling,I'm a heavy plant mechanic and you do get a small amount of glitter in the bigger boxes,I've got engine brakeing coming down the box in manual as well,I just would like to know about the box volts and if there's any common issues with them.thanks. |
the glitter in the gearbox is a sign of wear on the converter |
322BLL Member Since: 18 Apr 2019 Location: Estonia Posts: 73 ![]() ![]() |
Search RRPhil posts about this box.
Yes,they fitted a new valve body it's black instead of silver I don't know if that makes any difference,I know that glitter is a sign of wear but Iam definitely thinking is a voltage problem,I spoke to a few people that have had problems with the control ecu and wiring loom plugs to the gearbox,I don't have an issue pulling the box and reconditioning it my self but you can understand wanting to eliminate the voltage issues first.thanks |
Any ideas, anyone. |
