![]() | Home > Maintenance & Mods (L322) > Roof Rack Mounts |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1579 ![]() ![]() |
I nearly took some pix today. I'll do it tomorrow. Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
The Caravanstore isn't designed for a 4WD application but really to be mounted on the side of a caravan where it slides into a length of sail track (which is how I mounted it on my son's caravan).
I used it because I had it. To mount it, I pop-riveted a length of sail track extrusion to a suitable length of Unistrut channel I had lying about. The pic shows it slid back a bit for illustration purposes.
To mount the Unistrut channel on the roof tray, I had a couple of 75x50x50mm angle brackets which I bolted to the tray with 8mm bolts into threaded steel plates I made up. The Unistrut is bolted to the brackets with 10mm bolts into Unistrut clamp plates in the channel.
The plates are 20mm x 50mm x 5mm and slide into channels in the roof tray.
The Caravanstore is meant to lay against the wall of the van which supports the horizontal arms of the awning. As mine wasn't mounted this way, I had to weld a couple of tabs onto the Unistrut to act as backstops to the above arms. Hopefully my pics will make it clearer.
andyt109 Member Since: 23 Nov 2020 Location: London Posts: 29 ![]() ![]() |
Did you go with mondeo or RRS in the end? Thule hook around the doors just isn't a neat enough solution when there are bolt in mounts available. The thule 753 foot pack and any fixpoint system should be adaptable with some drilling or minor welding, I certainly hope so anyway. Cheers |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1024 ![]() ![]() |
Andy you have replied to a 4 year old thread, dont expect a reply any time soon. |
