![]() | Home > Maintenance & Mods (L322) > Moog Ball Joints opinions ? |
| b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319
Hi all,
Hearing your experience is why I am worried about the moog. But after watching that video it seems the Moog fluid movement is good and normal.. and seems good option.. I don’t know split opinion now 😂😂😂 2003 Range Rover 4.4 Litre V8 - Adriatic blue
| dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291
'moog' branding on the box may mean that the actual part came from the same production line as those in Delphi boxes or another brand or maybe it didn't or maybe Moog branded ones didn't get the same QC work done if it was a Tuesday etc etc.
Thanks for reply, Well not worth the risk ordered Genuine Land Rover Ball Joints to go with all the Delphi Parts.
I completely agree sir |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790
It depends on who has the contract to make which bit at what point in time for LR. OE and OEM is a minefield... a suspension part can be described as OEM when actually that manufacturer had the contract to make the.....ashtray for example. OE on the other hand means that the part is from the company who originally made that bit for the car, though there can be several OE brands for one part as suppliers change. (That’s how I understand it anyhow, could be wrong)
| JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 299
Just fitted Moog ARB links and they definitely look a bit thinner than the ones I took off.
| ur20v Member Since: 19 Feb 2019 Location: None Posts: 634
I agree, having worked for many Marques as a master tech for 30 years I have seen poor quality, manufacturing defects in parts straight from the manufacturer, just unboxing an LR part has little bearing over a good brand.
| MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 758
I fitted a moog ball joint to mine which didn't feel that smooth out of the box and began to experience clunking a month later.
| All times are GMT |
