![]() | Home > Technical (L322) > 07 supercharged won’t start? |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 612 ![]() ![]() ![]() |
First thing I would do is a hard reset, disconnect battery go for a cup of tea, check battery is good and reconnect.
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2250 ![]() ![]() ![]() |
I’ll do it in the morning and will check the battery hasn’t discharged too much. Where is the immobiliser if I need to find it ? Current stable:
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3327 ![]() ![]() ![]() |
I’d check the battery voltage. If it’s dipped whilst you’ve been on diagnostics all sorts of strange things can happen.
As above, sounds suspiciously like a simple flat battery... Oh too easy to overlook when stuff goes wrong! |
Ok chaps thanks so far - I have whipped the terminals off this morning and touched them together I have also stuck my battery charger on it. ill leave it until lunchtime and reassemble and feed back here... it is a monster battery though 110ah varta hence my hesitance Current stable:
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1404 ![]() ![]() |
Battery I'd say as well
you say that - I use age in my m6 as I have to they only seem to last 2 years or so now. They used to be Marta I believe and the first one from new lasted 5 years they switched to banner I get 2 year 3 if I'm luck before its at 50\5 and the car has a meltdown... Current stable:
Put it back together started first turn connected iid tool to the vim module and it had a fault lost communication with canbus hoping this isn’t the start of something bad Current stable:
