|  | Home > Technical (L322) > 07 supercharged won’t start? |
| bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 616      | First thing I would do is a hard reset, disconnect battery go for a cup of tea, check battery is good and reconnect.
|  3rd Jan 2021 11:33pm |
| Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2309      | I’ll do it in the morning and will check the battery hasn’t discharged too much. Where is the immobiliser if I need to find it ? Current stable:
|  3rd Jan 2021 11:38pm |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3349      | I’d check the battery voltage. If it’s dipped whilst you’ve been on diagnostics all sorts of strange things can happen.
|  3rd Jan 2021 11:41pm |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | As above, sounds suspiciously like a simple flat battery... Oh too easy to overlook when stuff goes wrong!  | ||
|  3rd Jan 2021 11:49pm |
| Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2309      | Ok chaps thanks so far - I have whipped the terminals off this morning and touched them together I have also stuck my battery charger on it. ill leave it until lunchtime and reassemble and feed back here... it is a monster battery though 110ah varta hence my hesitance Current stable:
|  4th Jan 2021 9:02am |
| dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1422    | Battery I'd say as well
|  4th Jan 2021 9:12am |
| Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2309      | you say that - I use age in my m6 as I have to they only seem to last 2 years or so now. They used to be Marta I believe and the first one from new lasted 5 years they switched to banner I get 2 year 3 if I'm luck before its at 50\5 and the car has a meltdown... Current stable:
|  4th Jan 2021 9:45am |
| Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2309      | Put it back together started first turn connected iid tool to the vim module and it had a fault lost communication with canbus hoping this isn’t the start of something bad Current stable:
|  4th Jan 2021 5:36pm |
| Posting Rules
