Home > Maintenance & Mods (L405) > Topped up AdBlue, still telling me to top up?
cass
Not sure if it's relevant with a Range rover but I came across a similar problem with a Jag XE belonging to a mate.
Warning message appeared, he bought some Adblue online and topped it up. The message and countdown continued, he was told that Jag sensors are "sensitive" to the correct (ie expensive Jag supplied) adblue to prevent tight gits diluting their adblue.
We drained his tank filled it with the expensive stuff and its worked fine ever since.
This could have been a coincidence, perhaps the cheaper stuff he bought had been overly diluted?
Possibly worth considering?
Post #578803 7th Jan 2021 12:20pm
according to google all adblues are the same so it could be a coincidence......
they should contain the same solution of 32.5% urea and 67.5% de-ionised water...
@geoff, dont worry with the lockdown probably extended to 2037 we wont be driving anywhere .. Wink ... - .- -.
Post #578805 7th Jan 2021 12:46pm
E46ACS
United Kingdom 2017 Range Rover Vogue TDV6 Loire Blue
SUCCESS!!!! A more considered approach to filling it up and the other 6l went in with no problems, and the warning messages have gone.
Lesson learnt on filling up the AdBlue. 2017 Loire Blue 3.0TDV6 Vogue
Post #578819 7th Jan 2021 1:41pm
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
Yet again the FullFat forum justifies the membership cost.
Shame you have to get the answer here rather than the company that takes your money for the car. letters not necessarily in the right order
Post #578847 7th Jan 2021 3:32pm
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
So I was filling up the AdBlue today. I was told by the LR Luxembourg service department to have the car on (not running) to fill it up... I had issues the first time I filled it up.
So today it was asking for 15L I filled it up it was about 16L. The car still says fill 7L... How do I reset it? SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #613710 24th Nov 2021 7:54pm
elsterracer
Germany 2018 Range Rover Vogue SDV8 Corris Grey
As I refilled myself yesterday I’d like to summarize answers to most questions that could raise when you want to refill yourself. Hope that helps…
WHEN TO FILL
My 2018 V8 model shows the amount that is necessary and how long the remaining DEF will last.
Other models (as in the video down below) or software versions do not show every detail.
WHAT TO FILL
DEF = Diesel Exhaust Fluid, much better known as AdBlue in Germany (it is the same)
RR says: ISO 22241-1 or DIN 70070. According to the Internet ISO 22241-1 is part of the ISO 22241 (and not a newer or older version of it).
You can buy this in
a) “screw in bottles” as suggested by RR (the more expensive but clean solution)
b) Standard cans from the gas station (the cheaper solution)
All standard cans I could e hold of in my town in Germany mention ISO 22241 (without "-1"). These are fine for the RR.
HOW TO FILL
Make sure you have a Diesel engine Wink
Park the car on a flat level surface!
Open the bonnet, go to the left side (looking in driving direction). Open the cap….
If you use Standard cans: Pour slowly, as bubbles will go upwards and otherwise the fluid spills over the car.
The necessary amount displayed by the car not necessarily is correct. In my case it displayed 13 liters, but app. 14 liters were filled. So you should rather buy more than displayed.
Reset of the display should happen automatically, however it seems (acc. to other experiences) to take a while until the car recognizes the refill.
TOXIC?
All sources say about the DEF/AdBlue:
a) not dangerous for car paint. Just clean away fluid or residue with water
b) yes, dangerous for eyes, nose etc.
c) not dangerous however for your hands, if you clean them with enough water
WARNINGS
If the DEF tank gets completely empty: Engine does not start (as foreseen by regulations)!
Additional Information
- shows (among other things) how to check the refill distance.
- Capacity of the tank according to stan: 18 liters
(corrections to my English are welcome by PN)
Post #659969 21st Mar 2023 12:40pm
JDGeorgia
United States 2006 Range Rover HSE 4.4 V8 Buckingham Blue
Just piling on...
I had the dreaded DEF Quality Error no starts in 250ish miles. I was 150 from home. Came home and got on YouTube. Pulled/cleaned the nozzle and drove 20ish miles. The error had changed to DEF Dosing Error, but did not clear.
I didn't have time to dick with it - took it to my Indy. They (incorrectly I believe) sold me a $2,500 Diesel Particulate Filter. That's fun - huh?
I had asked them to fill the DEF as part of this newly acquired DPF - I originally read the receipt as 3L of DEF, but it was 3EA 5L bottles of DEF - total of 15L!?!?! A month/500miles later - same issue. Censored Censored
I have since become a zealot for Jimmy O'Riley on YouTube. Dude has done hundreds of these and it always seems to be the same thing.
&t=2s
These things throw a Red Herring error. DEF Quality really means LOW DEF. I have since kept my DEF full to overfull. I just checked it today and it said 5,997 Miles to empty. The GAP IID tells me that it is overfilled Remove 3L and test again... It can be 1/10th of a liter over and it will tell you to drain 3L...
Here is a video I did on my DEF Experience. I have also become a fan of the closed AdBlue 1.89L Bottle. I bought 2 and use the 2.5 Gal to refill them - then use them to fill the truck. If you 'overfill' them up the neck - you can get right at 2L in them.
 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb'
Rolled Yahtzee Aug 2023 222,222Miles
2016 L405 HSE TD6. Santorini Black over Almond. - 'Donna the Diesel'
Only L405 IN THE KNOWN UNIVERSE with an L494 Shift Lever Fitted!
97K at purchase Sept of 2023
Post #691927 4th May 2024 9:44pm
baz000000
England 2016 Range Rover Autobiography SDV8 Loire Blue
Red Merle wrote:
Mine drains its tank from full in 6,000 miles, so it's less than half way to a service, but it's not far off the current oil change interval Sad
I think the consumption may be tied to the quality of fluid.
When I bought my car off a dealer I specified the Ad Blue tank be topped up. I would get random messages pop up about inferior quality Ad Blue and a tank full only lasted 11k miles in spite of the initial message saying it was good for 27k miles. I topped off with Screwfix special and that is lasting over twice as long in terms of time and miles covered.
I suspect the dealer could have topped off the tank from a watering can.
Post #692048 7th May 2024 9:52am
