![]() | Home > Technical (L405) > Predicament |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3853 ![]() ![]() ![]() |
I am sure lots of us are in exactly the same quandary.
Maccaa Member Since: 03 Feb 2020 Location: Bristol Posts: 38 ![]() ![]() ![]() |
There is a school of though that suggests just letting a car idle, doesn't stress the engine enough to properly attain working temperature and therefore can create more problems than it protects agains.
Gr4h4m Member Since: 08 Oct 2020 Location: Chester Posts: 88 ![]() ![]() ![]() |
Noco is a good alternative to a ctek but cheaper. I swapped when my ctek gave up the ghost |
AndyS Member Since: 27 Feb 2016 Location: Lymington, Hampshire Posts: 417 ![]() ![]() |
The lockdown won't be that long so just leave on trickle charger, it won't do it any harm. Occasionally starting and not driving will create condensation and then corrosion internally over time.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Leave it alone, leave it plugged in. Not doing any harm sitting. Repeatedly starting and not allowing the engine to come up to temp fully will cause more problems.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
Ctek it. Job done.
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1473 ![]() ![]() |
As I don't have tow electrics, is it possible to connect my ctek to the accessory socket in the boot?
The noco charger I have had an odb2 socket adapter, works great for the time I need to charge it. |
goddo Member Since: 27 Oct 2020 Location: south Posts: 83 ![]() ![]() |
I just connect my charger directly to the battery in the boot using the ctek adaptor. The charger sits on top of the spare wheel and the extension lead cable passes through the tailgate lids quite comfortably. |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
Do I read this correct; you charged your car using the OBD2 socket? I've never heard of anyone doing that, I must admit I wouldn't be comfortable doing that. I could have that wrong but there is way too much electronics linked in that area to use it for charging; I'd feel it is too easy to fry an ECU/module etc. I just charge using the actual jumpstart point in any car if required. Or often even better if I cant get it in my garage, just take the battery out. |
Rob99,
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
We are just swopping our cars around as my other half is still going to work, but as above leaving it say for a few weeks feels better than starting without going for a good run! Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
@Baltic Blue - Where would I find the main battery feed in the boot? 2011 TDV8 Vogue SE |
Dennij,
