Home > Technical (L405) > Predicament |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16171 |
A charger would be much more preferable... DONT start it to let it idle, leave it alone!
11th Jan 2021 12:13pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3679 |
, no problem I have just been in the garage and taken them, only to realise how dirty the carpet was under my rubber load mat. out with the vacuum before any of you eagle eyes comment
11th Jan 2021 12:16pm |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1328 |
Thanks Mike I'll be charging mine on the drive so I'll put the ctek just inside the tailgate. 2017 4.4 SDV8 Autobiography 2012 4.4 TDV8 Westminster - Gone, but not forgotten |
13th Jan 2021 11:45am |
That will be fine Rob..... the main advantage for me having the charger outside on the bumper is that I don’t need to open the tailgate to see the LED’s on the Ctek.... maybe you can see yours through the window ?
13th Jan 2021 12:29pm |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 |
Top tip from an idiot who knows,
13th Jan 2021 2:03pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34927 |
classic...... ... - .- -.
13th Jan 2021 2:16pm |
archermav Member Since: 01 Jun 2015 Location: Black Country Posts: 340 |
I have to talk wife into using mine for her drive to work every couple of weeks. Decent blast down the M6. Other wise it doesn't move, which after just paying £600 insurance is annoying |
13th Jan 2021 4:32pm |
insurance,tax and warranty's all being wasted because most of us cant use ours...depressing ... - .- -.
13th Jan 2021 5:06pm |
Look on the bright side Stan, your fuel bill is down and the jabs on its way.
13th Jan 2021 5:37pm |
only 2 fill ups since march 20 so saved a few bob Mike... ... - .- -.
13th Jan 2021 5:40pm |
JNC Member Since: 23 Feb 2020 Location: UK Posts: 292 |
The power feed is fused on the obd port. It wouldn’t affect anything else. You could only trickle charge through it. Sub 5amps. For that reason alone it wouldn’t really be worth while. Just connect to points under bonnet. As above, as long as battery is kept charged, tyres inflated, everything else will be fine sitting. Starting, idling will have negative effect long term. |
13th Jan 2021 7:03pm |
The “site shop” tow bar adapter comes with a handy reminder card to put in the instrument binnacle. There is nothing that can't be fixed with a hammer😜😜 FFRR 4.4 SDV8 Autobiography Santorini Black. Fiat 500x 1.4 multiair Lounge 2015 2010 LR D4 Commercial 2.7 TDV6 |
13th Jan 2021 7:34pm |
Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 716 |
Wow, that really is low usage! I've only had mine since mid June and I've filled it up 17 times, although that is less than half the mileage I did in the same period last year. MY23 Panamera E-Hybrid MY19 SDV8 Autobiography - Sold |
13th Jan 2021 7:55pm |
jackcramerr Member Since: 13 Oct 2019 Location: London Posts: 210 |
I hope you guys have consulted the relevant manual and not just blindly hooking up a charger to any point that is convenient.
14th Jan 2021 8:10pm |
