![]() | Home > Technical (L405) > Predicament |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16366 ![]() ![]() ![]() |
A charger would be much more preferable... DONT start it to let it idle, leave it alone!
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3843 ![]() ![]() ![]() |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1469 ![]() ![]() |
Thanks Mike ![]() I'll be charging mine on the drive so I'll put the ctek just inside the tailgate. 2021 D350 Fifty Edition - Carpathian Grey 2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black 2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black |
That will be fine Rob..... the main advantage for me having the charger outside on the bumper is that I don’t need to open the tailgate to see the LED’s on the Ctek.... maybe you can see yours through the window ?
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
Top tip from an idiot who knows, |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35747 ![]() ![]() |
archermav Member Since: 01 Jun 2015 Location: Black Country Posts: 354 ![]() ![]() ![]() |
I have to talk wife into using mine for her drive to work every couple of weeks. Decent blast down the M6. Other wise it doesn't move, which after just paying £600 insurance is annoying |
insurance,tax and warranty's all being wasted because most of us cant use ours...depressing |
only 2 fill ups since march 20 so saved a few bob Mike... ... - .- -.
JNC Member Since: 23 Feb 2020 Location: UK Posts: 293 ![]() ![]() ![]() |
The power feed is fused on the obd port. It wouldn’t affect anything else. You could only trickle charge through it. Sub 5amps. For that reason alone it wouldn’t really be worth while. Just connect to points under bonnet. As above, as long as battery is kept charged, tyres inflated, everything else will be fine sitting. Starting, idling will have negative effect long term. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
The “site shop” tow bar adapter comes with a handy reminder card to put in the instrument binnacle. There is nothing that can't be fixed with a hammer😜😜 FFRR 4.4 SDV8 Autobiography Santorini Black. KIA E-Niro 4+ 2021 Discovery 5 D300 MHEV commercial |
Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 802 ![]() ![]() |
Wow, that really is low usage! I've only had mine since mid June and I've filled it up 17 times, although that is less than half the mileage I did in the same period last year. MY23 Panamera E-Hybrid MY19 SDV8 Autobiography - Sold |
jackcramerr Member Since: 13 Oct 2019 Location: London Posts: 220 ![]() |
I hope you guys have consulted the relevant manual and not just blindly hooking up a charger to any point that is convenient.
