| Anyone with a 3.6TDV8 and Gap tool able to check something? | |
Looking for a bit of help if anyone can assist - I need someone with a GAP tool and a 3.6 TDV8, I dont think the 4.4 TDV8 will give the same values as the turbos on that are sequential, I think it has to be a 3.6 where the turbos work at the same time.
Anyway...
I'm getting the bong + ESF shortly after startup and my GAP tool is reporting
"P132B-21 (2F) Turbo/supercharger boost control A performance - General signal failure - signal amplitude<minimum"
I suspect I've got a sticky actuator, and checking the Live Values on the GAP tool, it's showing the Boost Pressure Actuator 2 is at 10%, whereas Boot Pressure Actuator 1 sits around 95%
Can anyone check on theirs and see if these values are the same as mine (10% and 95&) or the same as each other (i.e both are 95% or both are 10%) - reading various posts it could be the 95% is the stuck one, or might be the 10% one, not sure.
Anyway pretty sure reading the Workshop Manual I know which turbo it is, just looking for some confirmation so that I can be sure when I've fixed it which values I should be looking for.
Hope that makes sense. Image of IID log below, if it helps...
09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face)
Nissan X Trail 1.6TDCi Tekna
Fiat 500 1.2
