Home > Technical (L322) > Numpty award goes to me..!
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
So I got my new LED sidelight bulbs yesterday.... Went out when I got home to replace them and sit and watch the 6000k colour match with my Xenons.....
Fitted the bulbs and nothing.....
What's goin on here I thought, tried all the combinations, ignition on/off, door open, changed my socks etc... then started to have a closer look and realised, I'd taken out and replaced my main beam bulbs with the LED's... Doh Whistle
After I'd smacked my head a few times with a large lump of wood I "went in again" to find the right bulbs but couldn't work out how to remove the sidelights this time.. (it was dark by this time though).
Any clues as I'm sure it must be quite easy really.
Big Cry Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #58032 1st Apr 2011 8:14am
Question ..sidelights bulbs are tad smaller than the main beam bulbs, how did you do that?
the side lights have two white plastic butterfly nuts on the far inside of the wing. ... - .- -.
Post #58037 1st Apr 2011 8:41am
comports
Well they did fit no problem.... Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #58039 1st Apr 2011 8:42am
still scratching me head mate....mains are h7 bulbs and the sides are little 501's.... ... - .- -.
Post #58040 1st Apr 2011 8:46am
comports
hmmmm. Perhaps I ordered the worng things then. Rolling Eyes
These are the 68 bulb LED's as per Dan's post (http://www.fullfatrr.com/forum/topic5318.html) and what a KN0B I am. Just re read that post and it was infact for the high beam and not the sidelights.... That's why they fit there. Whistle
OK - So anyone know what LED bulbs I need for the sidelights per my original intention..
(Walks off, head held low in shame and embarrassement).. Embarassed Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #58044 1st Apr 2011 8:54am
Rolling with laughter Wink
i have these ones, [on the left in picture] brought off ebay...
Post #58045 1st Apr 2011 8:57am
Stan
Have you changed all your bulbs to LEDs? I've done most but need some for the interiour lights. The ones I got won't fit through the hole in the reflector. How much were you side light bulbs as think they would give a far better spread of light than the ones I have.
Post #58052 1st Apr 2011 9:20am
comports
And any pointers to the correct LED's to get for the side lights.
Could also do with upgrading the rear stop and tail lights to LED's.
Any clues anyone?
ps - Can't se eyour picture from here (probably bloxked website) Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #58054 1st Apr 2011 9:23am
havnt done the interior ones yet rob, but i have replaced the front sides , mains and fogs with leds...i've also changed the xenons to a higher temperature of 6000k.
btw my mains and fogs are not where they are normally [bit complicated Wink ].. ... - .- -.
Post #58055 1st Apr 2011 9:25am
pretlove
Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter brilliant Thumbs Up "RANGEISM WILL NOT BE TOLERATED"
Post #58162 1st Apr 2011 5:19pm
daveo
to do the interior led's, you are right they wont fit through the hole.." Idea you must look at the big picture here my friend" and do as i did .....put them in from the front Mr. Green V8 facelift Range Rover Autobiography 22" wheels.
Post #58166 1st Apr 2011 5:28pm
daveo
you need a pair of t10 bulbs as in scarey pic, depends on how bright you want them, i went for the single led and that was fine, dont go to high in the colour range 6000k are to blue for me i try to keep around the 5000k, standard xenons are 4500k...
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  V8 facelift Range Rover Autobiography 22" wheels.
Post #58173 1st Apr 2011 5:47pm
