Home > Technical (L322) > Error on suspension
paul70
Error on suspension
On Thursday I had little option to avoid a flooded road. I could see looking at the water level against the fence between the road and adjacent field that it was probably only around a foot or so deep but to be sure selected off road height. The car went up as it should and I drove through fine. As I sped up it automatically returned to standard height then I got the 'bong' of doom and orange warning symbol accompanied by only normal ride height available, this then cleared the next time I stopped and started the vehicle. Checked fault codes this morning and got the following faults.
ABS-Brake Module
U0421-68 (2Cool Invalid data received from ride level control module - Algorithm based failure - event information
( on 21-01-2021 13:11:41 at 125172 mi )
RLM-Suspension
C1A20-64 (6Cool Pressure increases too slow when filling reservoir - Algorithm based failure - signal plausibility failure
As both timed exactly same time I'm thinking its the second that's the problem and that's causing the first??
Does anyone have any ideas??
Am I looking at a new compressor??
For me not a great problem as only ever changed height a few times but want it working if I need it in anger.
Thanks
Post #580838 23rd Jan 2021 11:48am
Range Rover L322
Dry it out. Clear the fault codes. Let it go to sleep Dry it out some more. Clear the fault codes again. Sleep.
Dry it out a bit more and I bet they all go...
Post #580839 23rd Jan 2021 12:03pm
paul70
Thanks, I'll just kepp an eye on it for now. Found the following site
http://4x4airseals.com/shop
Lots of parts available and some do mention the fault code C1A20-64, not sure if mine is Hitachi or AMK as close to change over i think. Don't fancy emptying boot to look today as bloody freezing. Will take a look later this week,
Post #580946 24th Jan 2021 1:09pm
