![]() | Home > Maintenance & Mods (L322) > Which Engine Oil |
Gunni Member Since: 13 Jan 2018 Location: Dorset Posts: 16 ![]() ![]() ![]() |
It depends if you have a dpf. I use that oil in mine with no issues, mine is older but same engine. Jon
Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 200 ![]() ![]() ![]() |
Hi Gunni
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
The 3.6 is highly unlikely to have a DPF. Careful.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Did you mean a DPF? The 3.6 in the UK spec didn't get a DPF sir... Standard fit came along with the 4.4 TDV8 and yes that is 100% CRITICAL you use the correct oil in the 4.4 TDV8 ![]() |
My mistake as I was thinking of the 4.4v8td engine. Surprised that the 3.6 wasn't fitted with a dpf. Well spotted by the others: must get out more!
Tomc Member Since: 15 Oct 2020 Location: Belfast Posts: 37 ![]() ![]() ![]() |
Many thanks for the information, so in a nut shell my 3.6 has no DPF, should i use C1 type just in case or not really needed.
Throw your rego into the Opie Oils website and it will do the rest....
The 3.6 in certain market places was fitted with a DPF I believe... California springs to mind 👍 |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
My 3.6 doesn't have DPF . I went on the Opie website which confirmed the vehicle details of my car and recommended C1 which I am using. I went for the Millers 30W5. Am perfectly happy with it if that helps you. John 2008 Stornoway Grey 3.6 Tdv8 Vogue - SOLD 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT-Sold |
Perfect. Thank you for you help everyone.
