![]() | Home > Maintenance & Mods (L405) > Rear disks change |
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 236 ![]() ![]() |
Unlike on the Defender, the brake disk is sandwiched between the wheel and the hub so no need to remove the hub when replacing the disk. Simple job as long as nothing is seized, the workshop manual is in the wiki.
bear100 Member Since: 22 May 2011 Location: south wales Posts: 204 ![]() ![]() ![]() |
That’s great news, a bit cold out for a full stop down!
charlie croker mk2 Member Since: 21 Jun 2017 Location: Yorkshire Posts: 174 ![]() ![]() |
Easy job to do , just check your trolly jack is capable of lifting your car and you can protect your jacking points with the rubber inserts or jack it up under the wishbones , the only other "got you" is you need a multi point or external torx to remove the calliper bracket to hub bolt and its torqued up very very tight !
johnf Member Since: 16 Nov 2012 Location: Nottinghamshire Posts: 84 ![]() ![]() |
You'll also need to put the parking brake into service mode. Full details in the owners manual (see wiki) but essentially:
johnf : a very good point which I presumed the OP would know about LOL |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 672 ![]() ![]() |
Just did ours, the genuine parts were Brembo disks and TRW pads.
