Home > Maintenance & Mods (L405) > Rear disks change
bear100
Rear disks change
How easy are the rear disks to change? 2016 4.4
The lockdown and lack of use have corroded the rears for some reason
I have changed my Defender disks on a few occasions and wondered if its the same type with bearings to contend with? 2010 defender utility
2010 RRS TDV8 (gone)
2007 discovery 3 (gone)
2004 discovery 4 (gone)
1994 discovery 1
1970 v8 hybrid (gone)
1975 bobtail (gone)
Post #581934 31st Jan 2021 10:27pm
Fifth Horseman
Unlike on the Defender, the brake disk is sandwiched between the wheel and the hub so no need to remove the hub when replacing the disk. Simple job as long as nothing is seized, the workshop manual is in the wiki.
Before attempting to unscrew the torx bolt that holds the disk to the hub, insert the driver into the head and give it a couple of sharp hits with a hammer, this should help loosen it and make it easier to remove. I found out the hard way when I replaced my brake disks...
Post #581935 31st Jan 2021 10:40pm
bear100
That’s great news, a bit cold out for a full stop down!
Thanks for the tips 👍 2010 defender utility
1994 discovery 1
1975 bobtail (gone)
Post #581952 1st Feb 2021 9:05am
charlie croker mk2
Easy job to do , just check your trolly jack is capable of lifting your car and you can protect your jacking points with the rubber inserts or jack it up under the wishbones , the only other "got you" is you need a multi point or external torx to remove the calliper bracket to hub bolt and its torqued up very very tight !
Post #582005 1st Feb 2021 3:08pm
johnf
2013 Range Rover Autobiography 5.0 SC V8 Bonatti Grey
You'll also need to put the parking brake into service mode. Full details in the owners manual (see wiki) but essentially:
- Turn the ignition ON (not the engine) by pushing the start/stop button without stepping on the brake pedal
- Push the e-brake button down for 2 seconds and hold it (release the e-brake)
- Push the accelerator pedal down for 2 seconds and hold it
- Push the start/stop button twice (turn the ignition off and on)
Now the e-brake service mode is active.. you will hear a noise from the rear e-motors, when its releasing the e-brake to the service mode. Still hold the e-brake button and the accelerator pedal.
After the e-motors stops there will be info on the dash that the e-brake service mode is activated.
To deactivate the service mode is the same procedure, the only change is that you have to pull the e-brake button.
Post #582012 1st Feb 2021 4:11pm
charlie croker mk2
johnf : a very good point which I presumed the OP would know about LOL
Post #582013 1st Feb 2021 4:21pm
TJH1985
Just did ours, the genuine parts were Brembo disks and TRW pads.
Super easy job Thumbs Up MY17 Santorini Black L494 Autobiography 5.0 SC - Sorry!
Previously Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #585623 28th Feb 2021 9:03am
