![]() | Home > Maintenance & Mods (L405) > Battery problems |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874 ![]() ![]() |
have you 'told' the FF that it has a new battery via a diagnostic unit like the GAP iidtool.. ... - .- -.
Watty Member Since: 03 Oct 2013 Location: Kirkintilloch Posts: 56 ![]() ![]() ![]() |
No i have not i will give that a try in the moorning 07 Vogue SE Java Black 3.6 TDV8
Dave G Member Since: 30 Jul 2020 Location: Dorset Posts: 84 ![]() ![]() ![]() |
Is there a way to do this without an iid tool? 2013 Range Rover Autobiography 4.4 SDV8
updated FF just now took it a run still says battery low 😂😂😂 07 Vogue SE Java Black 3.6 TDV8 Black Leather heated/ cooled seats Piano black trim deployable side steps L405 Autiobiography 2017 Santorini Black with black pack 13 L405 4.4 Autobiography |
i have had a forum search and some say that the low battery message goes away after a few days , others mention a dashcam could be draining he battery..
What batteries have you fitted? When running, you say its 13.5v? Is this running without any vehicle electrics switched on? Like heated screens, blowers, lights & seats etc... With that little lot on, she should still achieve 14-14.4v sir... |
Good username for someone with battery problems. |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8135 ![]() ![]() ![]() |
Take the batteries back to be tested ?
Chalky Member Since: 10 Feb 2018 Location: Marshfield, Bath Posts: 931 ![]() ![]() |
Do you have a Blackvue Dashcam running in Parking mode? All LR cars from 1984
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
subbed. I've been getting low battery start vehicle errors when I shut off the car/enter. Seems to start when the temp gets very cold (below freezing). Debating getting a new battery....but interested to see if something else fixes your issue.
Brand new RR batteries fitted, dont get near 14.00 will try alternator next Thank you 07 Vogue SE Java Black 3.6 TDV8 Black Leather heated/ cooled seats Piano black trim deployable side steps L405 Autiobiography 2017 Santorini Black with black pack 13 L405 4.4 Autobiography |
Get the batteries tested first - even a new one can be faulty |
as above..and check the connections... ... - .- -.
so you went to dealer for OEM LR replacement? I'm on the look for what the OEM equivalent options are 2014 FF Autobiography 5.0 SC 2008 FFRR (sold) 2008 BMW M5 |
