![]() | Home > Technical (L322) > Need Advice: About to bid on L322 SC without power |
| Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322
Ultimately it is just a car; will need fuel, gas and spark to run |
| Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929
If only go for it if you can make your money back on breaking it. If its completely dead electrically then likely hood is its just a dead battery but you should get some form of life with a jump box on it like enough to turn the ignition on, test the central locking etc |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826
Or it's been in a flood and all the ecu's are broke, there are around 20 of them... Pete
And considering it’s an insurance auction they have likely already deemed it beyond economical repair. So I would highly doubt it is just a $200 battery but more going on with it.
| x3chab Member Since: 31 Jan 2021 Location: California Posts: 5
Thanks for all the advice!
You will have no idea how it became salvage, there are 1001 different scenarios ...
That makes sense. I’ll start looking at newer RRs. Thanks again for the advice. |
Totally agreed, no idea who that guys is either. Stuff happens to mechanical devices; heck apparently all Porsche V8's loose their bore lining and all BMW 7 series V8 also have a bore lining issue. Oh yeah and all Nissan Navara trucks blow their bottom end. There is a lot of noise on the internet. BTW I wasn't suggesting buying a new one, I was suggesting that it is not a good idea in my opinion to buy a broken older model unless you know what you are doing as it can become a money pit, especially if you have to pay others to fix it, and then you invest a lot in an older money that is simply not worth it...Buy a working one cheap, that is the best strategy |
Cliff is the publisher at offroadrover.com.
Also, I previously owned a 2010 LR4, so I know what I’m in for 🙃 |
| All times are GMT |
