Home > Technical (L322) > Need Advice: About to bid on L322 SC without power
x3chab
United States
Hi there,
I could really use some advice. There is an insurance auction '08 full fat SC that looks great, except that it won't start. Not only will it not start, but is also showing no signs of life at all - even with the use of a jumper box. The CarFax looks great, and everything else seems right. I even ordered an inspection.
It really sounds to me that the battery has just gone bad, but I'm worried that there could be some other catastrophic cause. My friend has suggested to me that the worst case scenario might be that the ECU is dead. If the ECU was dead, would it fail to illuminate all lighting?
Any further thoughts about the risks involved? (Other than I may be able to restore power and there still could be some kind of problem preventing it from driving properly).
Thank you.
Post #582307 4th Feb 2021 4:58am
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Ultimately it is just a car; will need fuel, gas and spark to run Smile And power to the ECUs to feed it...But only you know the true risks as you know your abilities and the depth of your pocket.
In my opinion I wouldn't bother unless extremely cheap, not just because it isn't running but also because it is the pre MY2010 model. The value just isn't there to sink money in those models in my opinion.
Post #582312 4th Feb 2021 8:20am
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
If only go for it if you can make your money back on breaking it. If its completely dead electrically then likely hood is its just a dead battery but you should get some form of life with a jump box on it like enough to turn the ignition on, test the central locking etc
Post #582318 4th Feb 2021 8:50am
Or it's been in a flood and all the ecu's are broke, there are around 20 of them... Pete
Post #582324 4th Feb 2021 9:19am
Bl4ckD0g
And considering it’s an insurance auction they have likely already deemed it beyond economical repair. So I would highly doubt it is just a $200 battery but more going on with it.
That doesn’t mean it can’t be repaired but without knowing what other damage it has it’s impossible to predict.
Post #582346 4th Feb 2021 1:12pm
x3chab
United States
Thanks for all the advice!
I was specifically looking for an 07-09 on the advice of Clifford Mark’s L322 Buyer’s Guide. He recommends avoiding MY2010 and up due to the high cost of ownership and repair and the timing chain issues. Is there a reason that MY2010 is a better buy?
Edit: I *am* aware that Rovers are always expensive to maintain and repair, but Cliff suggests that it’s much, much worse on MY2010 and up.
The idea of flood damage having fried all the ECUs is terrifying, although flood damage is not listed on the CarFax, the auction’s description of the damages, nor in the report I got from the inspector.
Post #582358 4th Feb 2021 3:20pm
You will have no idea how it became salvage, there are 1001 different scenarios ...
Never heard of this Clifford Mark but it is a fact that the post 2010 are the most reliable model, and they are not much more expensive to maintain than an earlier one, certain items are more but most servicing and the cost of service items are similar to the earlier ones..
The timing chain issue can be a problem but it is certainly not guaranteed to happen to them all, over here it is now a sub £2000 fix.
From my pole 70% on here have not been done... https://www.fullfatrr.com/forum/topic55495.html?vote=viewresult
If I were you I would get the latest you can find...
Have fun looking... Thumbs Up Pete
Post #582365 4th Feb 2021 4:19pm
x3chab
United States
That makes sense. I’ll start looking at newer RRs. Thanks again for the advice.
Post #582371 4th Feb 2021 4:46pm
Bl4ckD0g
Totally agreed, no idea who that guys is either. Stuff happens to mechanical devices; heck apparently all Porsche V8's loose their bore lining and all BMW 7 series V8 also have a bore lining issue. Oh yeah and all Nissan Navara trucks blow their bottom end. There is a lot of noise on the internet.
BTW I wasn't suggesting buying a new one, I was suggesting that it is not a good idea in my opinion to buy a broken older model unless you know what you are doing as it can become a money pit, especially if you have to pay others to fix it, and then you invest a lot in an older money that is simply not worth it...Buy a working one cheap, that is the best strategy Smile
Post #582414 4th Feb 2021 11:38pm
x3chab
United States
Cliff is the publisher at offroadrover.com.
http://offroadrover.com/range-rover-buying-guide/
I don’t know his username here, but he references this forum several time in the guide 👍
Post #582428 5th Feb 2021 4:39am
x3chab
United States
Also, I previously owned a 2010 LR4, so I know what I’m in for 🙃
Post #582429 5th Feb 2021 4:40am
