![]() | Home > Technical (L405) > Deployable towbar - deploy & stow queries |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3926 ![]() ![]() ![]() |
There's nothing in the Wiki as far as I can see but there is something in the manual - tried it a few times. While I'm eating my McDonalds today (little treat) after having my first COVID jab I'll have another play. |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 ![]() ![]() |
Not sure if this is what you've seen in the manual but this is the reset process.
Thats what it says in the manual and I've tried it a few times to no avail. However inspired by you and Craig taking the trouble to reply I just nipped out and tried again - Voila - it worked.
Hi Geoff - there is a known issue with some of the original towbar electrical modules. Might be worth checking because the newer module can be found on ebay for about £25.
Thanks Nick - I'll have a look they seem cheap enough on eBay (lots of AG's). I haven't had a look at mine yet, too cold. Geoff |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Take it off and buy a new mechanism. Easiest option usually sir |
ESS Member Since: 10 Jun 2025 Location: Prague Posts: 4 ![]() ![]() |
Hi gents,
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8061 ![]() ![]() ![]() |
Try removing the fuse 5 behind the glove box - check yours are the same, but this is what my manual says
Thanks, will try.
