Home > Maintenance & Mods (L322) > Broken wheel stud on l322
Shawser1203
United Kingdom 2010 Range Rover HSE TDV8 Zermatt Silver
Hi folks.
Tried to take off wheel stud, the stud is the 17mm tapered type. The stud broke, leaving the shoulder of stud and tapered piece still in the wheel. Any ideas how to get it out?
Post #583178 10th Feb 2021 9:35pm
D3Jon
Hi Shawser,
That doesn't look like a standard / factory nut? They usually include a captive washer.
But anyway, I'd think to get what's left of that off, It'll need a well placed air-chisel with a sharp point to drive it around.
If it sheered getting it off, I can't imagine you could weld anything to it that would do any better... That really looks like a really nasty problem.
One last thought, a garage with an inductive heater thingy + air chisel?
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #583187 10th Feb 2021 11:17pm
Shawser1203
Yeh it's a nasty one. I've been looking on you tube and seems best way is to drill it out, then replace the stud. Did think a small hole saw might do it. Drill in and cut the shoulder off.
Post #583195 11th Feb 2021 7:33am
stuart_2006
Is there room around it to fit a 'rounded bolt extractor socket' - the type that bites onto the outside with a reverse thread? Or is it deep in a recess in the wheel?
Post #583238 11th Feb 2021 12:34pm
A large hammer and a long 12mm bolt. Thumbs Up
Post #583241 11th Feb 2021 12:52pm
Shawser1203
Unfortunately the stud isn't separate from the hub.
Post #583248 11th Feb 2021 2:01pm
If you have genuine wheels then your nuts should look like this...
The one you pictured could be for aftermarket wheels, if they have been used on genuine wheels then I'm not surprised it broke as the taper will have been forced into the rebate of the hole and I suspect you will have a damaged wheel...
You need to get to the bottom of the issue as well as get the rest of the nut off... Thumbs Up Pete
Post #583250 11th Feb 2021 2:13pm
D3Jon
That's a good suggestion, if (as you say) the tool will fit down the wheel 'hole'.
I have a set of Irwin ones, but never found them to be much good on anything I've ever tried.
I did see this video on YouTube by Project Farm (who I think brilliant BTW), demonstrating other brands with some pretty impressive results though:
2014 Disco 4 HSE
Post #583253 11th Feb 2021 2:35pm
Shawser1203
They are aftermarket wheels.
Post #583261 11th Feb 2021 3:15pm
Shawser1203
Post #583262 11th Feb 2021 3:17pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
If it was me I would split the remains of the nut. To do this I would accurately drill small holes as close together as possible starting as close to the hub bolt as possible.
Then using a small chisel split the remains of the nut, if it wont move by splitting on one side then repeat on the opposite side.
Although I have done this on all sorts of nuts, I've never done it on a wheel nut but may be worth a try.
good luck. Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #583264 11th Feb 2021 3:32pm
D3Jon
Having looked at that picture, there doesn't seem to be anything left to get hold of. It's all in the taper of the wheel mounting hole.
The only other thing to do, is drill out the stud, I'm sorry to say.
It'd need carefully centre punching and then drilling out with a succession of drill bits, going up in size until you get to 12 or 13mm without going so big as to damage the wheel itself. You'd only have to drill to a depth the same as the length of what's left of the wheel nut (say 10 or 12mm).
Then the wheel should come off and you could replace the drilled out stud (although I think they're regarded as non-replaceable) or better still replace the entire hub.
2014 Disco 4 HSE
Post #583265 11th Feb 2021 3:34pm
Shawser1203
Yip, you have to replace the hub. I'll try drilling it first.
Post #583270 11th Feb 2021 4:02pm
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Depends how handy you are with tools I guess.
Easiest way would be is get an induction heater to heat up the area and get a chisel and see if you can create a gap and then do the same on the other side. Once you've done this you'd need too make up your "key" if you like. Think of it like an angle grinder key but a vertical version of it
Post #583277 11th Feb 2021 4:40pm
Shawser1203
The hole saw worked. 4mm pilot hole in stud, then 20 mm hole saw. Slight enlargement to hole in the wheel, but nothing to be concerned about.
Post #583299 11th Feb 2021 10:01pm
