Home > Technical (L322) > Halfords batteries?
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
Halfords batteries?
for a 2010 car they list 2 options and both come with a 5 years warranty
https://www.halfords.com/motoring/batterie...earch=true
it seems the 019 is the correct size so why they list a smaller one (which is £44 cheaper) and still offer 5 years warranty?.
I haven't got 5 years out of the genuine LR one so thinking of a change.
Has anyone fitted the cheaper Halfords battery? 2010 VSE [Roger]
Post #578086 2nd Jan 2021 12:34pm
D3Jon
Auto Express tested batteries a few years back and highly rated Halford's Advanced batteries with Calcium technology.
I just did a quick search and it's still avilable online: https://www.autoexpress.co.uk/accessories-...s-reviewed
As an aside, I've had very good experience with the Hancook batteries available on Ebay. Had one on a very power hungry Audi A8 with air suspension, electric everything and a 4.2 Diesel V8 (so similar to a L322 in many regards). Was on the car for 4 years until I sold it and never a spot of bother and that car was used in-frequently, often standing for weeks at a time.
The most issues I've had have been with Bosch batteries from Euro Car Parts costing twice as much as the Hancook!
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #578095 2nd Jan 2021 1:04pm
019 is the correct size. 017 isn’t......
When I put my 16MY in it comes up with the 019 AGM which is generally correct, but I would check that you have an AGM as some 2010’s did and some didn’t iirc. There was a swap over when they started putting in AGM batteries. If you haven’t got an AGM then it may be possible to tell the car you have installed one and the charging system will adapt. There is nothing that can't be fixed with a hammer😜😜
Post #578097 2nd Jan 2021 1:05pm
dexion7
mine has AGM and both those Halford ones are also AGM. cant go wrong with the 5 year guarantee even for the cheaper one at £142? 2010 VSE [Roger]
Post #578122 2nd Jan 2021 2:21pm
Personally can’t see the smaller one. The problem will be the smaller one will be lower capacity in terms of AH and CCA. General rule of thumb is generally go as big as you can.... Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #578124 2nd Jan 2021 2:24pm
dexion7
its Halford 115 AGM battery - they recommend it as an alternative to the 019 for 3.6tdv8. its 800cca and only 80 a/h but 5 year warrantee and £142 2010 VSE [Roger]
Post #578127 2nd Jan 2021 2:54pm
80 is a bit on the small side for a 3.6 especially if you have a FBH running. personally if you are set on the Halfords ones I would go for the larger one. There is nothing that can't be fixed with a hammer😜😜
Post #578128 2nd Jan 2021 3:09pm
Pikey
I've got the Halfords one, the larger (proper size) one. Running absolutely perfect fine for about a month so far throughout extremely cold weather and short journeys Smile Pikey by name, not by nature Smile
Post #578377 4th Jan 2021 10:11am
Arbuckle
United Kingdom 2012 Range Rover Westminster 4.4 V8 Fuji White
Halfords batteries are made by Yuasa. Seem to do well during independent tests.
20% discount with a Halfords trade card. Forty years of progress. 1972-2012
Post #583721 14th Feb 2021 7:49pm
TJH1985
We only got 3 years out of a Yuasa from Halfords on the L322, but they exchanged it without any hassle so can’t complain especially given how our RR’s torture batteries! MY17 Santorini Black L494 Autobiography 5.0 SC - Sorry!
Previously Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #583760 14th Feb 2021 10:12pm
D3Jon
I've gone off Yuassa batteries, having just had a problem with a brand new one from a well known mail-order seller.
I'm not going to say who, because they've been absolutely brilliant at exchanging the battery and it's not really their fault. But I bought a Yuassa 3669 cargo for my JCB digger. Put it on my capacative tester before fitting and it was only putting out 650A CCA (EN), vs a specified 925 CCA (EN), Health was aroud 25% despite having healthy volts of 13.1.
I had it tested by a local garage as well and their Bosch analyser came up with the same results.
The seller confirmed they had a batch issue and were going to conduct a recall of the 10 or so Yuassa 669 batteries they'd sold recently, because every one they had in stock showed similar poor results.
They recommended a replacement of a Numax which they sent out without hesitation (yeah I know it sounds cheap), but it has the correct vibration resistance required for a digger application. It was rated at 950A, and was belting out a whopping 975 when tested, so happy chappy.
2014 Disco 4 HSE
Post #583898 15th Feb 2021 6:30pm
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Had a Halfords battery on mine for the last 15 months, no issues. Thumbs Up
Post #583938 15th Feb 2021 9:31pm
