![]() | Home > Technical (L322) > Removing front NS Wheel arch. |
| RichTD6 Member Since: 02 Mar 2011 Location: Lincolnshire Posts: 85
Do you have a Dremmel type tool that you could cut/grind the head off with gently? I’ve used that method before with good results! 🙂 2012 Westminster TDV8 4.4 Indus Silver
| Chris1573 Member Since: 30 Jan 2021 Location: Gloucestershire Posts: 162
Yes Rich Dremmel is on charge ! I will try cutting a slot first if that fails then I will cut it off. Will fix it back with Stainless Steel as it should last longer that the current type. L322 2007 TDV8 3.6 |
| All times are GMT |
