|  | Home > Technical (L322) > Removing front NS Wheel arch. |
| RichTD6 Member Since: 02 Mar 2011 Location: Lincolnshire Posts: 85      | Do you have a Dremmel type tool that you could cut/grind the head off with gently? I’ve used that method before with good results! 🙂 2012 Westminster TDV8 4.4 Indus Silver
|  15th Feb 2021 5:59pm |
| Chris1573 Member Since: 30 Jan 2021 Location: Gloucestershire Posts: 162      | Yes Rich Dremmel is on charge ! I will try cutting a slot first if that fails then I will cut it off. Will fix it back with Stainless Steel as it should last longer that the current type. L322 2007 TDV8 3.6 | ||
|  15th Feb 2021 6:49pm |
|  15th Feb 2021 7:51pm |
| Posting Rules
 Good call on the stainless fittings too! I’ve replaced quit a few of the screws and bolts with stainless on mine too now.
