Home > In Car Electronics (L322) > TV Reception - is everyone's this bad or just me?
kooky_guy
Not wanting to hijack other TV threads, I thought I'd better start my own...
The reception on the TV in my 2010 seems very hit and miss (mostly miss).
Is this generally the case for all of these, or does it sound like there's something wrong with mine? I appreciate it's a digital signal and it will suffer from freezing etc when on the move but mine seems to be more than that.
Basically, when I'm travelling the reception will drop out for long periods of time before eventually coming back for a bit and then dropping out again etc. Even stationary outside the house, sometimes it will get a signal and other times there will be no channels available.
Looking at these sorts of threads, I do get the impression that everyone else's seems to work better than mine, but I'm not really sure what to expect. Its hard to believe they would bother fitting it at all if they were all this bad though.
Am I correct in that there are 4 antenna amplifier modules? Is there anything that can be done to test them? Or is it a case of replacing them? Are the antennas all in the side windows?
The kids like to watch it and the DVD player still doesn't work. Luckily we're not going anywhere at the moment but I'm sure the complaints will start anew when we can! 2010 4.4 TDV8 Vogue SE
Post #584183 17th Feb 2021 6:45pm
mjdronfield
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #584190 17th Feb 2021 7:46pm
kooky_guy
Thank you for that. Very informative.
So only two amplifiers to investigate! 2010 4.4 TDV8 Vogue SE
Post #584191 17th Feb 2021 7:54pm
Think you will find TV on the move is pretty awful, it does depend where you are though...!! Pete
Post #584193 17th Feb 2021 7:59pm
mjdronfield
Looks like 2 antennas and 2 amplifiers.
I don’t think Digital TV was really designed to be used on the move, more for the stationary TV in your living room.
Only tried mine stationary.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #584196 17th Feb 2021 8:33pm
kooky_guy
Mine seems to be equally awful while stationary though.
Maybe I'm expecting too much! 2010 4.4 TDV8 Vogue SE
Post #584198 17th Feb 2021 8:54pm
mjdronfield
You might need to retune it if you are a few miles from where you last retuned it. Seems ok after that.
Can’t suggest anything else I’m afraid.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #584203 17th Feb 2021 9:11pm
kooky_guy
It seems to stop completely with no channels available. Then they all come back some time later.
Sometimes it's a blessing. Wink 2010 4.4 TDV8 Vogue SE
Post #584215 17th Feb 2021 10:52pm
