Home > Maintenance & Mods (L322) > TDV8 4.4 Belt Help Needed
Dstew
Changed belt tensioner but after 5 minutes running belt shredded. Indy has fitted new belt but it has shredded again. All pulleys look fine. Any ideas?
Post #584266 18th Feb 2021 1:02pm
have a read of this 'how to' from our wiki, it might help identify your problem,
https://www.fullfatrr.com/forum/topic48934.html ... - .- -.
Post #584269 18th Feb 2021 1:12pm
Dstew
Have been through the wiki. Don't understand why a tensioner change should cause belt failure after 5 minutes. Then another new belt failure immediately. Any other ideas?
Post #584293 18th Feb 2021 2:19pm
D3Jon
If you can rule out the obvious first, such as pulley damage, pulley mis-alignment, or simply catching on something.
I'd then take a look at the driven ancillaries, especially the a/c compressor and check it's running freely with A/C on (clutch engaged).
Also check out the alternator and then ensure the radiator fan can spin freely. If the blades are caught, you wouldn't know until the engine was hot and the viscous coupling has engaged.
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #584303 18th Feb 2021 3:13pm
Dstew
Solved the problem. Indy has replaced the tensioner I fitted with a genuine one and it’s now fine.
The one I bought from John Craddock made by Britpart was utter rubbish. Ridges on the pulley were forcing the belt off and snagging it. After a quick google it seems Britpart are to be avoided.
Rather cross with retailer as web picture is of a genuine part.
This has cost me two belts and 8 hours labour.
You can see the problem on the photo.
Post #584517 20th Feb 2021 8:39am
GGDR
I bought something from John Craddock listed as, and shown in pic as genuine and it came as Britpart.
Complained and they were not bothered.
. Cheers, Greg
Post #584518 20th Feb 2021 9:17am
Dstew
I’ve sent them the photo and will follow it up with a report from the Indy.
Will give them a chance to do the right thing.
More news when I have it.
Post #584520 20th Feb 2021 9:20am
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
i just had all of mine done and the tension pully that came off after 115k looked in better shape than that.
i think the tensioner i used was genuine got them from Advanced Factors and Rimmer Bro's as neither had all items in stock. 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #584531 20th Feb 2021 10:54am
Dstew
Same here. The pulley on the old one with 120k looked fine. But the the belt was running right up to the edge so needed changing.
Post #584533 20th Feb 2021 11:12am
D3Jon
I'm not a Britpart fan, some of there stuff is ok and I've used bits & bobs on Defender's and RR Classics in the past, but wouldn't use anything from them on either of my L322's.
I've had failures of new Britpart components (and 'All-Make' ones for that matter), when offroading in the middle of knowhere and not been in the slightest impressed! So lessons learnt.
There are some good alternative part suppliers for our beloved cars and so far I've been impressed with discs from Borg & Beck, front lower arms from Delphi, suspension bushes & rear knuckles from Lemforder and brake pads from Brembo. Pretty much everything else though needs to be Genuine IMHO.
2014 Disco 4 HSE
Post #584618 20th Feb 2021 8:06pm
Remove the B and insert as S!
S H I T P A R T enough said!
Post #584652 21st Feb 2021 12:05am
D3Jon
Brilliant! Rolling with laughter 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Post #584832 22nd Feb 2021 4:28pm
Dstew
Engine all now running fine with new genuine tensioner. Now in discussion with John Craddock over their liability for selling such shoddy parts. Interesting to note that they have now changed the web page for this item and it no longer shows a picture of a genuine part box.
Post #584886 23rd Feb 2021 7:00am
